(defun test (lst / a lst2) (while (setq a (car lst)) (setq lst (cdr lst)) (while (= (car lst) a) (setq lst (cdr lst)) ) (setq lst2 (cons a lst2)) ) (reverse lst2))
(test '(a b c c c d c o))
caoyin发表于2009-7-28 12:43:00(defun test (lst / a lst2) (while (setq a (car lst)) (setq lst (cdr lst)) (while (= (car lst) a) (setq lst
(test '(a b c c c d c o))测试结果 (A B C D C O)
以下是引用狂刀无痕在2009-7-29的发言:(defun test (lst / ll) (setq ll(list(car lst))) (mapcar'(lambda(x)(if(not(equal x (car ll)))(setq ll(cons x ll)))) lst) (reverse ll) ) (defun test (lst / ll) (setq ll(list(car lst))) (mapcar'(lambda(x)(if(not(equal x (car ll)))(setq ll(cons x ll)))) lst) (reverse ll) )
caoyin 发表于 2009-7-27 17:24 (defun test (lst / a lst2) (while (setq a (car lst) lst2 (cons a lst2) lst (vl-remove a l ...
本版积分规则 发表回复 回帖后跳转到最后一页
GMT+8, 2025-12-17 09:45 , Processed in 0.155040 second(s), 18 queries , Gzip On.
