楼主: 英雄无敌
[分享]批量倒角
发表于 2012-12-15 18:53:31 | 显示全部楼层
真的不错,结合xlx一起用,哈哈
发表于 2012-12-16 20:15:23 | 显示全部楼层
顶出源码 发来看看吧
发表于 2013-4-12 15:08:20 | 显示全部楼层
感谢楼主分享,试用了一下,发现有以下问题:当图形靠边得近的时候,就会出错!见图片!
发表于 2013-6-11 14:23:26 | 显示全部楼层
很好用,谢谢了
发表于 2013-6-11 16:31:00 | 显示全部楼层
好呀,的确不错,
发表于 2014-2-6 01:06:15 | 显示全部楼层
很需要这个功能!多谢楼主
发表于 2014-4-10 22:34:02 | 显示全部楼层
真的很好,多谢分享
发表于 2014-8-5 16:29:47 | 显示全部楼层
谢谢分享。
发表于 2014-9-22 10:33:06 | 显示全部楼层
谢谢,顶个,我新手,我发一个源代码不知道怎么用,帮我看看吗
(defun filletgp
                (/ ssl1        ssl2 pt1 pt2 pt3 pt4 num num1 num2 i li1 li2
                 intp1 intp2 nli1 nli2 dist ddd)
  (setvar "CMDECHO" 0)
  (setq ddd (getvar "FILLETRAD"))
  (setq dist (getdist (strcat "\nPlease input fillet radius<" (rtos ddd) ">:")))
  (if (/= dist nil)
    (setvar "FILLETRAD" dist)
  (setq
    pt1        (getpoint "\nPlease select frist group line:\nFrist point:")
  (initget 32)
  (setq        pt2
            (getpoint pt1 "Second point:")
        pt3
            (getpoint "\nPlease select second group line:\nFrist point:"
  (initget 32)
  (setq        pt4  (getpoint pt3 "Second point:")
        ssl1 (ssget "F" (list pt1 pt2) '((0 . "line")))
        ssl2 (ssget "F" (list pt3 pt4) '((0 . "line")))
        num1 (sslength ssl1)
        num2 (sslength ssl2)
        num  (min num1 num2)
        i    0
  (repeat num
    (setq li1        (ssname ssl1 i)
          li2        (ssname ssl2 i)
          intp1        (inters        pt1
                        pt2
                        (cdr (assoc 10 (setq nli1 (entget li1))))
                        (cdr (assoc 11 nli1))
          intp2        (inters        pt3
                        pt4
                        (cdr (assoc 10 (setq nli2 (entget li2))))
                        (cdr (assoc 11 nli2))
    (command "_.fillet" (list li1 intp1) (list li2 intp2))
    (if        (/= (cdr (assoc 8 nli1)) (cdr (assoc 8 nli2)))
        (setq nli2 (subst (assoc 8 nli1) (assoc 8 nli2) (entget li2)))
        (entmod nli2)
    (setq i (1+ i))
(defun C:fg (/ osort)
  (if (= (rem (setq osort (getvar "sortents")) 2) 1)
      (setvar "sortents" (- osort 1))
      (filletgp)
      (setvar "sortents" osort)
    (filletgp)
发表于 2014-9-22 10:34:33 | 显示全部楼层
命令   "FG"
GMT+8, 2026-1-19 18:43 , Processed in 3.102972 second(s), 20 queries , Gzip On.
