楼主: 英雄无敌
[分享]批量倒角
发表于 2015-8-10 15:56:53 | 显示全部楼层
强大
发表于 2015-8-11 12:53:18 | 显示全部楼层
我能说我明经币本来就很少吗
发表于 2016-10-19 09:09:18 | 显示全部楼层
看似很强大,可惜没有币
发表于 2016-10-19 16:57:43 | 显示全部楼层
感谢分享,谢谢!!!
发表于 2017-9-25 14:04:11 | 显示全部楼层
因为没有什么网友感兴趣,也就不献丑了
发表于 2018-2-14 22:49:06 | 显示全部楼层
谢谢楼主分享,程序很不错。
发表于 2018-2-15 07:41:35 | 显示全部楼层
Here is one that does multiple chamfer of lines.
  1. ;;; multiple Chamfer
  2. ;;; Marko Ribar
  3. ;;; hxxp://forums.augi.com/showthread.php?44929-Looking-for-a-routine-for-Multiple-Fillet&p=1228192&viewfull=1#post1228192
  4. (defun c:mcha ( / *error* mid AssocOn ss i ent p1 p2 lin linn lins flins ptlst1 pt1 pt11 ptlst2 pt2 pt22 chpts chamfers )
  5.   (vl-load-com)
  6.
  7.   (defun *error* ( msg )
  8.     (if chma (setvar 'chamfera chma))
  9.     (if chmb (setvar 'chamferb chmb))
  10.     (if chmm (setvar 'chammode chmm))
  11.     (vla-endundomark (vla-get-activedocument (vlax-get-acad-object)))
  12.   )
  13.   (defun mid ( p1 p2 )
  14.     (mapcar '(lambda ( a b ) (/ (+ a b) 2.0)) p1 p2)
  15.   )
  16.   (defun AssocOn ( SearchTerm Lst func fuzz )
  17.     (car
  18.       (vl-member-if
  19.         (function
  20.           (lambda (pair) (equal SearchTerm (apply func (list pair)) fuzz))
  21.         )
  22.         lst
  23.       )
  24.     )
  25.   )
  26.   (vla-startundomark (vla-get-activedocument (vlax-get-acad-object)))
  27.   (mapcar 'set '(chma chmb chmm) (mapcar 'getvar '(chamfera chamferb chammode)))
  28.   (mapcar 'setvar '(chamfera chamferb chammode) '(0 0 0))
  29.   (prompt "\nSelect line entities")
  30.   (while (not (setq ss (ssget "_" '((0 . "LINE"))))))
  31.   (setq i -1)
  32.   (while (setq ent (ssname ss (setq i (1+ i))))
  33.     (setq p1 (trans (vlax-curve-getstartpoint ent) 0 1))
  34.     (setq p2 (trans (vlax-curve-getendpoint ent) 0 1))
  35.     (setq lin (list p1 p2))
  36.     (setq lins (cons lin lins))
  37.   )
  38.   (setq flins (apply 'append lins))
  39.   (foreach lin lins
  40.     (setq ptlst1 (vl-sort flins '(lambda ( a b ) (< (distance (car lin) a) (distance (car lin) b)))))
  41.     (if (equal (cadr ptlst1) (cadr lin) 1e-8) (setq pt1 (caddr ptlst1)) (setq pt1 (cadr ptlst1)))
  42.     (if (setq linn (assocon pt1 lins 'car 1e-8)) (setq pt11 (mid (car linn) (cadr linn))))
  43.     (if (setq linn (assocon pt1 lins 'cadr 1e-8)) (setq pt11 (mid (car linn) (cadr linn))))
  44.     (setq ptlst2 (vl-sort flins '(lambda ( a b ) (< (distance (cadr lin) a) (distance (cadr lin) b)))))
  45.     (if (equal (cadr ptlst2) (car lin) 1e-8) (setq pt2 (caddr ptlst2)) (setq pt2 (cadr ptlst2)))
  46.     (if (setq linn (assocon pt2 lins 'car 1e-8)) (setq pt22 (mid (car linn) (cadr linn))))
  47.     (if (setq linn (assocon pt2 lins 'cadr 1e-8)) (setq pt22 (mid (car linn) (cadr linn))))
  48.     (setq chpts (list pt11 (mid (car lin) (cadr lin))) chamfers (cons chpts chamfers) chpts (list pt22 (mid (car lin) (cadr lin))) chamfers (cons chpts chamfers))
  49.   )
  50.   (foreach chpts chamfers
  51.     (command "_.chamfer" (car chpts) (cadr chpts))
  52.   )
  53.   (*error* nil)
  54.   (princ)
  55. )
发表于 2018-12-15 14:16:11 | 显示全部楼层
这个东东,真的很好用
发表于 2018-12-15 14:23:48 | 显示全部楼层
好用,快速方便!
发表于 2018-12-15 21:19:43 | 显示全部楼层
确实不错,方便多了,不然一个个倒角挺麻烦,谢谢分享
GMT+8, 2026-1-19 17:04 , Processed in 0.186420 second(s), 20 queries , Gzip On.
