楼主: highflybir
[【高飞鸟】] 【飞鸟集】ToolTip ,气泡通知
发表于 2011-5-17 14:14:11 | 显示全部楼层
回复 sachindkini 的帖子
Can you register DynamicWrapperX by hand?
发表于 2011-5-17 15:40:06 | 显示全部楼层
回复 highflybird 的帖子
dear sir,
not clear for me, by hand mean?
yes i can register manualy
发表于 2011-5-17 16:58:59 | 显示全部楼层
回复 sachindkini 的帖子
How about to Create a DynamicWrapperX instance.
(setq DWX (vlax-create-object "DynamicWrapperX"))
if  the return value  is not  nil, then ,you needn't to run RegisterDynWrapX.
发表于 2011-5-19 13:01:21 | 显示全部楼层
dear sir,
sorry for delay, result is nil
  1. Command: (setq DWX (vlax-create-object "DynamicWrapperX"))
  2. nil
 楼主| 发表于 2011-5-19 14:25:03 | 显示全部楼层
回复 sachindkini 的帖子
Can you register  Dynwrapx.dll?
copy  dynwrapx.dll to your   windows\system32\
then  run : regsvr32.exe  dynwrapx.dll
Register the component in one of these two ways:
regsvr32.exe path-to-the-component\dynwrapx.dll - for all users.
regsvr32.exe /i path-to-the-component\dynwrapx.dll - for the current user.
If dynwrapx.dll is located in the System32, System, Windows directory, the current directory or one of those listed in the PATH environment variable, the path is optional. After registering dynwrapx.dll for the current user, the DynamicWrapperX object will only be available to this user.
Unregister the component as follows:
regsvr32.exe /u path-to-the-component\dynwrapx.dll - for all users.
regsvr32.exe /u /i path-to-the-component\dynwrapx.dll - for the current user.
On Windows 98 you will possibly have to specify the full path to regsvr32.exe (the System folder). Also, registration for the current user makes no sense here because the component won’t work.
http://www.script-coding.com/dynwrapx_eng.html
发表于 2011-5-19 14:37:48 | 显示全部楼层
Dear Sir,
Thx for helping
see the next error
 楼主| 发表于 2011-5-19 14:56:51 | 显示全部楼层
回复 sachindkini 的帖子
Maybe you should check your system security setting?
or you can register an account in this website,then ask the author directly.
this is the link:
http://forum.script-coding.com/viewforum.php?id=22
I also asked the author some questions about dynamicWrapperX:
http://forum.script-coding.com/viewtopic.php?id=5583
 楼主| 发表于 2011-5-19 15:19:51 | 显示全部楼层
回复 sachindkini 的帖子
First check you login system as administrator.
http://support.microsoft.com/kb/827659
Maybe this is helpful.
http://social.msdn.microsoft.com ... 0-accc-d96eb9a416fe
发表于 2011-5-19 16:33:19 | 显示全部楼层
Dear sir,
thx for reply, & sorry i will not check my admin policy,
my company administrator disabled the regedit, i will try at my home today night
发表于 2020-2-20 14:35:34 | 显示全部楼层
你们好厉害!都用上 英语对话,我是一点也没看懂!对了,"sachindkini"朋友,你是哪个国家的啊?既然能看懂我们的汉字,为什么不用汉字和我们沟通啊?
GMT+8, 2026-1-18 16:52 , Processed in 0.159502 second(s), 19 queries , Gzip On.
