楼主: spring
如何得到選中物體的座標資料???
发表于 2003-7-23 17:12:00 | 显示全部楼层
是EXPRESSTOOL中的公共函數
(ARXLOAD "ACETUTIL.ARX" NIL)
The acetutil modules (acetutil.arx, acetutil*.fas) provide a number of utility functions which can be called from LISP.
(acet-ent-geomextents ename)
Returns the geometric extents of the given object.
Arguments
ename The entity name of an object.
Return Values
A list containing two points (such as ((1.0 1.0 0.0) (2.0 2.0 0.0))) describing the geometric extents
 楼主| 发表于 2003-7-23 18:52:00 | 显示全部楼层
我的2000早就卸載了
我的2000早就卸載了,2002有嗎???
发表于 2003-7-24 08:00:00 | 显示全部楼层
本站應有提供!你找找!
发表于 2003-7-24 09:13:00 | 显示全部楼层
龙龙仔发表于2003-7-23 17:12:00是EXPRESSTOOL中的公共函數
这些帮助从哪儿可以看到?
发表于 2003-7-24 11:23:00 | 显示全部楼层
;; trap run-time error.
(defun ai_error (errmsg)
   (if (not (member errmsg '("console break" "Function Cancelled"
        "bad argument type" "Function cancelled" "no function definition: DOS_GETPROGRESS"
          "bad argument" "函数被取消" "quit / exit abort"))
      ) ;_ end of not
      (princ (strcat "\nError: " errmsg))
);_defun
;; Get all nodes of the LWPolyline, Polyline.
(defun GetListOfPline (EntityName / SSE_Pline N newEntityName)
(setq SSE_Pline (entget EntityName))
(setq LastList nil)
(if (= (cdr (assoc 0 SSE_Pline)) "LWPOLYLINE")
      (setq LastList (LIST (LIST 0 0)))
      (setq N 0)
      (while (/= (nth N SSE_Pline) nil)
             (if (= (car (nth N SSE_Pline)) 10)
                 (setq LastList (append LastList (list (list (cadr (nth N SSE_Pline)) (caddr (nth N SSE_Pline)) )) ))
             (setq N (+ N 1))
      (setq LastList (cdr LastList))
(if (= (cdr (ASSOC 0 SSE_Pline)) "OLYLINE")
    (PROGN
      (setq LastList (list (list 0 0)))
      (setq newEntityName (entnext EntityName))
      (while (= (cdr (assoc 0 (entget newEntityName))) "VERTEX")
             (setq LastList (append LastList (list (list (cadr (assoc 10 (entget newEntityName))) (caddr (assoc 10 (entget newEntityName))) ))))
             (setq newEntityName (entnext newEntityName))
(setq LastList LastList)
);_defun
;; main function
(defun c:maxmin ( / old_cmd old_osm sel_set i pt_list rad cen x0 y0 pt_minx pt_miny pt_maxx pt_maxy cen_x cen_y ret_val)
  (setq old_cmd (getvar "cmdecho"))
  (setvar "cmdecho" 0)
  (setq old_osm (getvar "osmode"))
  (setvar "osmode" 0)
  (setq old_error  *error*                ; save current error function
        *error* ai_error                ; new error function
  (prompt "\nSelect entity:")
  (setq sel_set (ssget))
  (if sel_set
      (setq i 0)
      (repeat (sslength sel_set)
        (setq ent_name (ssname sel_set i))
        (setq ent_list (entget ent_name))
        (cond
          ((or (= (cdr (assoc 0 ent_list)) "LWPOLYLINE")(= (cdr (assoc 0 ent_list)) "OLYLINE"))
           (setq pt_list (append pt_list (GetListOfPline ent_name)))
          ((= (cdr (assoc 0 ent_list)) "CIRCLE")
           (setq rad (cdr (assoc 40 ent_list)))
           (setq cen (cdr (assoc 10 ent_list)))
           (setq x0 (car cen)
                 y0 (cadr cen)
           (setq pt_list (append pt_list (list (list (- x0 rad) (+ y0 rad))(list (+ x0 rad) (- y0 rad)))))
          (t)
        );_cond
        (setq i (+ i 1))
      );_repeat
      (if pt_list
          (setq pt_minx (apply 'min (mapcar 'car pt_list))
                pt_miny (apply 'min (mapcar 'cadr pt_list))
                pt_maxx (apply 'max (mapcar 'car pt_list))
                pt_maxy (apply 'max (mapcar 'cadr pt_list))
                cen_x (/ (+ pt_minx pt_maxx) 2)
                  cen_y (/ (+ pt_miny pt_maxy) 2)
          (setq ret_val (list (cons "10" (list pt_minx pt_miny))
                              (cons "11" (list pt_maxx pt_maxy))
                              (cons "cen" (list cen_x cen_y))
        (princ "\nNo 'Polyline' or 'Circle' entity!")
      );_if
    );_progn
    (alert "No entities selected!")
  );_if
  ; Draw a rectangle to mark the range of the selected entities( Pline or Circle).
  (if (and ret_val (/= (cdr (car ret_val)) (cdr (cadr ret_val))))
      (command "rectang" (cdr (car ret_val)) (cdr (cadr ret_val)) 3)
  );_if
  (setvar "cmdecho" old_cmd)
  (setvar "osmode" old_osm)
  (setq *error* old_error)
  ret_val        ;return list.
);_defun
包含三个函数:
  1. ai_error 错误跟踪;
  2.GetListOfPline 计算多义线坐标;
  3.c:maxmin 主函数.
发表于 2003-7-24 11:43:00 | 显示全部楼层
再上传
我发的帖子,很长时间看不到?只好再发一次.什么原因呢?
发表于 2003-7-24 11:47:00 | 显示全部楼层
可能你没有刷新吧
发表于 2003-7-24 13:39:00 | 显示全部楼层
谢谢
谢谢meflying版主奖励的积分.
 楼主| 发表于 2003-7-24 18:40:00 | 显示全部楼层
謝謝咣生兄的回答.
謝謝咣生兄的回答.
以前前生寫的一個程序,找了好久才找到,不過我的腦袋瓜太笨了,看不懂.
;;;______________________________________________________
(defun c:myy ()
  (Defun my (ben / count doc handles l1 l2 count y1 y2)
    (setq count 0)
    (setq lyx nil)
    (setq lyy nil)
    (SetQ doc (VLA-Get-ActiveDocument (VLAX-Get-ACAD-Object)))
    (while (< count (sslength ben))
      (setq ent1 (ssname ben count))
      (Setq
        handles
         (Cdr (Assoc 5 (EntGet ent1)))
      (VLA-GetBoundingBox
        (VLA-HandleToObject doc handles)
        'llp
        'urp
      (setq l1 (VLAX-SafeArray->List llp))
      (setq lyx (cons (Car l1) lyx))
      (setq lyy (cons (Cadr l1) lyy))
      (setq l2 (VLAX-SafeArray->List urp))
      (setq lyx (cons (Car l2) lyx))
      (setq lyy (cons (Cadr l2) lyy))
      (setq count (1+ count))
    (setq lyx (vl-sort lyx '<))
    (setq lyy (vl-sort lyy '<))
  (setq ss (ssget))
  (my ss)
 楼主| 发表于 2003-7-24 18:47:00 | 显示全部楼层
王咣生发表于2003-7-24 11:43:00再上传
372
我有有過類試的情況,有時候貼子找不到了,必須要搜索才可以
GMT+8, 2025-12-17 05:49 , Processed in 0.166205 second(s), 19 queries , Gzip On.
