楼主: yxl88168
图层名自动更改
发表于 2011-6-16 22:19:50 | 显示全部楼层
(defun c:tt (/ en la date y m d NEW la_new)
  (SETVAR "CMDECHO" 0)
  (if (setq en (entsel))
      (setq la (cdr (assoc 8 (entget (car en)))))
      (cond ((wcmatch la "*新制u*")(setq la_new (substr la (+ (vl-string-search "新" la) 6))))
            ((wcmatch la "*修改*")(setq la_new (substr la (+ (vl-string-search "修" la) 6))))
            (t (setq la_new la))
      (setq date (rtos (getvar "cdate")2 0))
      (setq y (substr date 1 4))
      (setq m (substr date 5 2))
      (setq d (substr date 7 2))
      (setq date (strcat  y "." m "." d))
      (setq NEW (strcat "(" date "修改)" la_new))
      (command "_.rename" "layer" la NEW )
  (command "REDRAW")
发表于 2011-6-16 23:13:47 | 显示全部楼层
回复 yxl88168 的帖子
      (if (wcmatch la "(*)*")
        (setq la_new (substr la (+ (vl-string-search ")" la) 2)))
        (setq la_new la)
  (command "REDRAW")
发表于 2011-9-9 17:26:32 | 显示全部楼层
好程序,谢谢楼主
发表于 2011-11-10 09:24:19 | 显示全部楼层
感谢楼主分享!
发表于 2011-11-24 13:00:24 | 显示全部楼层
感谢24楼的lohas1118    不知道能不能改为 图层手工输入名称
发表于 2011-11-24 16:17:15 | 显示全部楼层
           自已手动改还可以随意改的
发表于 2020-12-5 20:36:47 | 显示全部楼层
好贴好贴,学习了。
GMT+8, 2026-1-17 18:54 , Processed in 0.162996 second(s), 19 queries , Gzip On.
