楼主: amberilee
请教大虾,如何在一个cad文件里查找给定的关键字?用vba
发表于 2003-7-25 19:12:00 | 显示全部楼层
这个多重偏移程序给你,希望它可以帮到你做表格!程序代码如下:
Sub callp()
On Error GoTo err
Dim keyWord As String
'选择偏移模式
ThisDrawing.Utility.InitializeUserInput 0, "Add Noadd"
keyWord = ThisDrawing.Utility.GetKeyword _
(vbCrLf & "输入选项[分段偏移(A)/总长偏移(N)]:<分段偏移> ")
If keyWord = "" Then keyWord = "Add" '若为空则默认分段偏移
'MsgBox keyWord
Select Case keyWord
Case "Add"
Call soffset1
Case "Noadd"
Call soffset2
End Select
err:
Exit Sub
End Sub
Sub soffset1() '分段进行偏移
'偏移命令中的偏移值是正值的情况,将在线进向的左,否在右
On Error GoTo err
Dim offdist(58) As Variant
Dim s As Integer
Dim i As Integer
Dim spnt As Variant
Dim epnt As Variant
Dim ts As String
Dim points As Variant
Dim sset As AcadSelectionSet
For i = 0 To ThisDrawing.SelectionSets.Count - 1
    ThisDrawing.SelectionSets.Item(i).Clear
    ThisDrawing.SelectionSets.Item(i).Delete
Next
Set sset = ThisDrawing.SelectionSets.Add("offsetobj")
sset.SelectOnScreen
If sset.Item(0).ObjectName = "AcDbPolyline" Then
points = sset.Item(0).Coordinates
    If points(1) > points(3) Then
            ts = "请输入偏移距离:[正值向左,负值向右]"
            ElseIf points(1) < points(3) Then
            ts = "请输入偏移距离:[正值向右,负值向左]"
            ElseIf points(1) = points(3) And points(0) < points(2) Then
             ts = "请输入偏移距离:[正值向下,负值向上]"
             ElseIf points(1) = points(3) And points(0) > points(2) Then
             ts = "请输入偏移距离:[正值向上,负值向下]"
    End If
ElseIf sset.Item(0).ObjectName = "AcDb2dPolyline" Then
    If points(1) > points(4) Then
               ElseIf points(1) < points(4) Then
               ElseIf points(1) = points(4) And points(0) < points(3) Then
                   ElseIf points(1) = points(4) And points(0) > points(3) Then
    End If
    ElseIf sset.Item(0).ObjectName = "AcDbLine" Then
    spnt = sset.Item(0).StartPoint
    epnt = sset.Item(0).EndPoint
        If spnt(1) < epnt(2) Then
            ElseIf spnt(1) > epnt(1) Then
             ElseIf spnt(1) = epnt(1) And spnt(0) < epnt(0) Then
              ElseIf spnt(1) = epnt(1) And spnt(0) > epnt(0) Then
        End If
End If
Dim offobj As Variant
offdist(0) = 0
s = 1
ss:
offdist(s) = ThisDrawing.Utility.GetReal(ts)
offdist(s) = offdist(s) + offdist(s - 1)
offobj = sset.Item(0).Offset(offdist(s))
offobj(0).Color = acGreen
s = s + 1
GoTo ss
Exit Sub
err:
Exit Sub
End Sub
Sub soffset2() '以总长进行偏移
On Error GoTo err
Dim s As Integer
Dim i As Integer
Dim ts As String
Next
sset.SelectOnScreen
    End If
    End If
            End If
End If
s = 1
ss:
s = s + 1
GoTo ss
Exit Sub
err:
Exit Sub
End Sub
 楼主| 发表于 2003-7-25 21:43:00 | 显示全部楼层
我们做表格就是画直线,然后偏移
发表于 2003-7-25 23:17:00 | 显示全部楼层
呵呵,那就简单了,我做了一个表格绘制程序,放在“编程申请”里,你去下载用吧!
GMT+8, 2026-1-14 02:53 , Processed in 0.155373 second(s), 17 queries , Gzip On.
