楼主: tryhi
[函数] GCD高程点z值修复[原创.附源码]
发表于 2017-9-4 20:57:37 | 显示全部楼层
谢谢实用好工具
发表于 2017-9-14 23:58:02 来自手机 | 显示全部楼层
收藏了会用得着,谢谢分享
发表于 2017-9-17 15:22:43 | 显示全部楼层
虽然看不懂 但是觉得很厉害
发表于 2017-9-18 16:22:24 | 显示全部楼层
谢谢楼主的劳动成果!
发表于 2018-1-15 19:36:33 | 显示全部楼层
不错,谢谢楼主的分享!
发表于 2020-7-3 21:07:52 | 显示全部楼层
为什么没改过来
发表于 2020-7-4 21:31:20 | 显示全部楼层
我正好需要相反的
发表于 2024-5-16 00:25:51 | 显示全部楼层
;GCD设置cass定义的属性块gcd200插入点Z坐标的值写到高程属性(height值)中去
(defun C:GCD (/ SS JD I EN0 EN1 ENT0 ENT1 PT0 STR)
  (if (SETQ SS (ssget '((0 . "insert") (2 . "*"))))
      (if (SETQ JD (getint "\n小数保留位数<4>: "))()(SETQ JD 4))
      (repeat (SETQ i (sslength SS))
                                (SETQ EN0  (ssname SS (SETQ i (1- i)))
                                        ENT0 (entget EN0)
                                        EN1  (entnext EN0)
                                        ENT1 (entget EN1)
                                (SETQ PT0 (cdr (assoc 10 ENT0))) ;_插入点
                                (SETQ STR (rtos (caddr PT0) 2 JD)) ;_新内容
                                (entmod (subst (cons 1 STR) (assoc 1 ENT1) ENT1))
                                (entupd EN0) ;_更新
发表于 2024-5-16 00:31:20 | 显示全部楼层
;;;GCDD设置cass定义的属性块gcd中高程属性(标高或height值)为其插入点的z坐标
(DEFUN C:GCDD()(GCDD2024)(princ))
(defun GCDD2024(/ bt11 e h hh jd n s)
        (princ "GCDD设置cass定义的属性块gcd中高程属性(标高或height值)为其插入点的z坐标QXQ")
        (defun bt11 (e / s)
                (if (and (setq e (vlax-ename->vla-object e))
                                        (vla-Get-HasAttributes e)
                                (foreach x
                                        (vlax-safearray->list (vlax-variant-value (vla-GetAttributes e)))
                                        (if (OR (= "标高" (vla-Get-TagString x)) (= "height" (vla-Get-TagString x)))
                                 ;(if (= "标高" (vla-Get-TagString x))
                                                (setq s (cons (vla-Get-TextString x)s))
                                (if s (car s))
        (if (and (or (setq JD (getint "\n小数保留位数<4>: "))
                                                 (setq jd 4)
                                ;(setq s (ssget '((0 . "insert") (2 . "GC*"))))
                                (setq s (ssget '((0 . "insert")(2 . "GC*"))))
                                (setq n (sslength s))
                (while (and (setq e (ssname s (setq n (1- n))))
                                                 (setq h (bt11 e))
                                                 (setq h (read h))
                                                 (numberp h)
                                                 (setq h (atof (rtos h 2 jd)))
                                                 (setq hh (vlax-get e 'InsertionPoint))
                        (vlax-put e 'InsertionPoint (list (car hh)(cadr hh) h))
GMT+8, 2026-1-7 11:15 , Processed in 0.171657 second(s), 19 queries , Gzip On.
