楼主: mandala
两个小问题:
发表于 2011-9-16 11:29:33 | 显示全部楼层
DosLib14
dos_copy
Copies a file. The function can be used to copy a file from one directory to another, and from one drive to another.
Syntax
(dos_copy srcfilename destfilename)
Arguments
srcfilename        Source file name. Must be the path name of an existing file.
destfilename        Destination file name. If this file exists, it will be overwritten.
Returns
A qualified path to destfilename.
nil on error.
发表于 2011-9-16 19:10:08 | 显示全部楼层
推荐 Andyhon 兄的建议,SHELL本身无法判断文件是否复制成功,只能从目标文件判断
 楼主| 发表于 2011-9-17 16:03:40 | 显示全部楼层
还有个办法。用shell 复制源文件到任意目录下,另取一个文件名为aaa.dwg,再用move命令将aaa.dwg移动至目标路径。然后findfile aaa.dwg,如果aaa.dwg存在,则move成功。
GMT+8, 2025-12-16 18:26 , Processed in 0.174499 second(s), 24 queries , Gzip On.
