楼主: cabinsummer
[【风之影】] [源码]动态粗糙度
发表于 2015-1-22 19:17:29 | 显示全部楼层
不知道VB.net怎么做!
发表于 2015-6-15 21:10:11 | 显示全部楼层
终于找到了。。虽然目前以我的水平看不懂源码,但程序非常好用。谢谢楼主分享!!!
发表于 2017-12-21 10:19:06 | 显示全部楼层
下载了就过来 顶贴人性化程序,不错赞个~
发表于 2017-12-23 16:00:51 | 显示全部楼层
没错,这就是我一直在找的源码
收藏之,谢谢楼主
发表于 2022-5-13 18:15:07 | 显示全部楼层
收藏之,谢谢楼主
发表于 2022-5-27 11:01:10 | 显示全部楼层
这个程序真好用,加入我的工具箱了。修改了一下,把幻灯片和对话框整合到sp里了
;;; *风之影粗糙度绘制,langjs修改
(defun c:ccd (/ $value a ang b bname c code dcl_pt dcl_re dclname do dra drb edata ename era erb f kname llist loop myerr
                nearpnt olderr os p00 p1d p1u p2d p2u p3d p3u pcd pcu pqy prcs ptd ptu ra rb scl snappnt value x
  (defun do_list ()
    (start_list "RV" 1)
    (setq value (nth (atoi $value) llist))
    (end_list)
    (set_tile "error" (strcat "粗糙度为 Ra" value))
  (defun myerr (msg)
    (command "undo" "e")
    (setvar "osmode" os)
    (entdel ename)
    (setq *error* olderr)
  (defun image (a b c)
    (if (= a 0)
        (start_image "RM")
        (fill_image 0 0 48 48 4)
        (vector_image 20 40 40 5 5)
        (vector_image 20 40 12 26 5)
        (vector_image 28 26 12 26 5)
        (vector_image 20 41 40 6 5)
        (vector_image 20 41 12 27 5)
        (vector_image 28 27 12 27 5)
        (end_image)
        (start_image "RM")
        (fill_image 0 0 48 48 5)
        (vector_image 20 40 40 5 7)
        (vector_image 20 40 12 26 7)
        (vector_image 28 26 12 26 7)
        (vector_image 20 41 40 6 7)
        (vector_image 20 41 12 27 7)
        (vector_image 28 27 12 27 7)
        (end_image)
    (if (= b 0)
        (start_image "UN")
        (vector_image 18 26 23 26 5)
        (vector_image 17 27 18 27 5)
        (vector_image 23 27 24 27 5)
        (vector_image 16 28 17 28 5)
        (vector_image 24 28 25 28 5)
        (vector_image 16 29 16 32 5)
        (vector_image 25 29 25 32 5)
        (vector_image 16 33 17 33 5)
        (vector_image 24 33 25 33 5)
        (vector_image 17 34 18 34 5)
        (vector_image 23 34 24 34 5)
        (vector_image 18 35 23 35 5)
        (end_image)
        (start_image "UN")
        (vector_image 18 26 23 26 7)
        (vector_image 17 27 18 27 7)
        (vector_image 23 27 24 27 7)
        (vector_image 16 28 17 28 7)
        (vector_image 24 28 25 28 7)
        (vector_image 16 29 16 32 7)
        (vector_image 25 29 25 32 7)
        (vector_image 16 33 17 33 7)
        (vector_image 24 33 25 33 7)
        (vector_image 17 34 18 34 7)
        (vector_image 23 34 24 34 7)
        (vector_image 18 35 23 35 7)
        (end_image)
    (if (= c 0)
        (start_image "BS")
        (end_image)
        (start_image "BS")
        (end_image)
  (defun do_a ()
    (setq value (cadr (member value llist)))
    (if value
        (refresh ra)
        (refresh rb)
      (setq value "50")
  (defun do_s ()
    (setq value (cadr (member value (reverse llist))))
    (if value
        (refresh ra)
        (refresh rb)
      (setq value "")
  (defun refresh (bname / kname edata)
    (tblnext "block" t)
    (while (/= (cdr (assoc 2 (setq kname (tblnext "block")))) bname))
    (setq edata (entget (cdr (assoc -2 kname))))
    (entmod (subst
              (cons 1 value)
              (assoc 1 edata)
              edata
    (entupd ename)
  (defun create_ra ()
    (entmake (list '(0 . "BLOCK") '(10 0 0 0) '(70 . 1) '(2 . "*U")))
    (entmake (list '(0 . "TEXT") (cons 10 p00) (cons 11 ptu) (cons 7 (getvar "DIMTXSTY")) '(8 . "DIM") '(40 . 2.5) '
                   (62 . 3) '(72 . 4) (cons 1 value)
    (cond
      ((= prcs 1)
        (entmake (list '(0 . "LINE") '(62 . 4) (cons 10 p1u) (cons 11 p2u) '(8 . "DIM")))
      ((= prcs 2)
        (entmake (list '(0 . "CIRCLE") '(62 . 4) (cons 10 pcu) '(40 . 1.33) '(8 . "DIM")))
    (entmake (list '(0 . "LINE") '(62 . 4) (cons 10 p00) (cons 11 p2u) '(8 . "DIM")))
    (entmake (list '(0 . "LINE") '(62 . 4) (cons 10 p00) (cons 11 p3u) '(8 . "DIM")))
    (setq ra (entmake '((0 . "ENDBLK"))))
    (entmake (list '(0 . "INSERT") (cons 10 p00) (cons 41 scl) (cons 42 scl) (cons 2 ra)))
    (setq era (entlast))
    (setq dra (entget era))
  (defun create_rb ()
    (entmake (list '(0 . "TEXT") (cons 10 p00) (cons 11 ptd) (cons 7 (getvar "DIMTXSTY")) '(8 . "DIM") '(40 . 2.5) '
    (cond
      ((= prcs 1)
        (entmake (list '(0 . "LINE") '(62 . 4) (cons 10 p1d) (cons 11 p2d) '(8 . "DIM")))
      ((= prcs 2)
        (entmake (list '(0 . "CIRCLE") '(62 . 4) (cons 10 pcd) '(40 . 1.33) '(8 . "DIM")))
    (entmake (list '(0 . "LINE") '(62 . 4) (cons 10 p00) (cons 11 p2d) '(8 . "DIM")))
    (entmake (list '(0 . "LINE") '(62 . 4) (cons 10 p00) (cons 11 p3d) '(8 . "DIM")))
    (setq rb (entmake '((0 . "ENDBLK"))))
    (entmake (list '(0 . "INSERT") (cons 10 p00) (cons 41 scl) (cons 42 scl) (cons 2 rb)))
    (setq erb (entlast))
    (setq drb (entget erb))
  (defun do_left ()
    (setq snappnt (cadr code))
    (entdel ename)
    (if (osnap snappnt "nea")
        (entdel ename)
        (create_ra)
        (create_rb)
        (entdel erb)
        (setq ename era)
        (entdel ename)
        (setq dra (subst
                    (cons 50 0.0)
                    (assoc 50 dra)
                    dra
        (setq dra (subst
                    (cons 41 (* 1.25 (cdr (assoc 41 dra))))
                    (assoc 41 dra)
                    dra
        (setq dra (subst
                    (cons 42 (* 1.25 (cdr (assoc 42 dra))))
                    (assoc 42 dra)
                    dra
        (entmod dra)
        (entmake (list '(0 . "TEXT") (cons 7 (getvar "DIMTXSTY")) '(8 . "DIM") '(10 0.0 0.0 0.0) (cons 40 (* scl 4.0))
                       (cons 41 0.8) '(62 . 3) '(72 . 4) (cons 11 (mapcar
        (mapcar
        (function (lambda (x)
        (* scl x)
        pqy
        snappnt
                                                         ) '(1 . "其余")
        (setq loop nil)
  (defun do_right ()
    (setq loop nil)
    (entdel ename)
  (defun do_move ()
    (entdel ename)
    (setq nearpnt (osnap snappnt "nea"))
    (if nearpnt
        (setq ang (angle nearpnt snappnt))
        (cond
          ((and
             (>= ang (/ pi 6.0))
             (<= ang pi)
            (setq ang (- ang (/ pi 2.0)))
            (entdel era)
            (setq ename era)
            (setq dra (subst
                        (cons 10 nearpnt)
                        (assoc 10 dra)
                        dra
            (setq nearpnt nil)
            (setq dra (subst
                        (cons 50 ang)
                        (assoc 50 dra)
                        dra
            (entmod dra)
          ((or
             (= ang 0.0)
             (and
               (> ang (* (/ pi 6.0) 7.0))
               (< ang (* pi 2.0))
            (setq ang (+ ang (/ pi 2.0)))
            (entdel erb)
            (setq ename erb)
            (setq drb (subst
                        (cons 10 nearpnt)
                        (assoc 10 drb)
                        drb
            (setq nearpnt nil)
            (setq drb (subst
                        (cons 50 ang)
                        (assoc 50 drb)
                        drb
            (entmod drb)
          (t
            (entdel era)
            (setq ename era)
            (setq nearpnt nil)
        (entdel era)
        (setq ename era)
        (setq dra (subst
                    (cons 10 snappnt)
                    (assoc 10 dra)
                    dra
        (setq dra (subst
                    (cons 50 0.0)
                    (assoc 50 dra)
                    dra
        (entmod dra)
        (setq nearpnt nil)
  (setvar "cmdecho" 0)
  (vl-load-com)
  (setq os (getvar "osmode"))
  (setq olderr *error*)
  (setq *error* myerr)
  (setvar "osmode" 0)
  (command "undo" "be")
  (setq scl (getvar "dimscale"))
  (setq value "3.2")
  (setq prcs 1)
  (setq dclname (vl-filename-mktemp "rough.dcl")
        f (open dclname "w")
  (write-line "roughness:dialog{ label=\"风之影粗糙度\"; spacer; " f)
  (write-line " :row { :column {  " f)
  (write-line ":image_button { key = \"RM\"; aspect_ratio = 1; width = 8; fixed_width = true; color = graphics_background; allow_accept = true; }"
              f
  (write-line ":image_button { key = \"UN\"; aspect_ratio = 1; width = 8; fixed_width = true; color = graphics_background; allow_accept = true; } "
              f
  (write-line ":image_button { key = \"BS\"; aspect_ratio = 1; width = 8; fixed_width = true; color = graphics_background; allow_accept = true; } } "
              f
  (write-line ":list_box { key=\"RV\"; value=8; width=16; height=14; allow_accept=true; } } " f)
  (write-line ":errtile { width=18; } ok_cancel;}" f)
  (close f)
  (setq dcl_re (load_dialog dclname))
  (new_dialog "roughness" dcl_re "" dcl_pt)
  (setq llist '("" "0.025"
         "0.05" "0.1"
         "0.2" "0.4"
         "0.8" "1.6"
         "3.2" "6.3"
         "12.5" "25"
         "50"
  (start_list "RV")
  (mapcar
    'add_list
    llist
  (end_list)
  (image 0 0 0)
  (set_tile "RV" "8")
  (set_tile "error" (strcat "粗糙度为 Ra3.2"))
  (action_tile "RM" "(image 1 0 0) (setq prcs 1)")
  (action_tile "UN" "(image 0 1 0)  (setq prcs 2)")
  (action_tile "BS" "(image 0 0 1)  (setq prcs 0)")
  (action_tile "RV" "(do_list)")
  (action_tile "accept" "(done_dialog 1)(setq do T)")
  (action_tile "cancel" "(done_dialog 0)")
  (start_dialog)
  (unload_dialog dcl_re)
  (vl-file-delete dclname)
  (if do
      (setq p00 '(0.0 0.0 0.0))
      (setq p1u '(2.3094 4.0 0.0))
      (setq p2u '(-2.3094 4.0 0.0))
      (setq p3u '(5.7735 10.0 0.0))
      (setq pcu '(0.0 2.67 0.0))
      (setq ptu '(0.0 6.5 0.0))
      (setq p1d '(-2.3094 -4.0 0.0))
      (setq p2d '(2.3094 -4.0 0.0))
      (setq p3d '(-5.7735 -10.0 0.0))
      (setq pcd '(0.0 -2.67 0.0))
      (setq ptd '(0.0 -6.5 0.0))
      (setq pqy '(-9.0 3.0 0.0))
      (create_ra)
      (create_rb)
      (entdel erb)
      (prompt "\n选择插入点,[A键]增加,[S键]减小:")
      (setq ename era)
      (setq loop t)
      (while loop
        (setq code (grread t 15 0))
        (cond
          ((= (car code) 5)
            (do_move)
          ((= (car code) 3)
            (do_left)
          ((or
             (= (car code) 11)
             (= (car code) 25)
            (do_right)
          ((or
             (equal code '(2 97))
             (equal code' (2 65))
            (do_a)
          ((or
             (equal code '(2 115))
             (equal code' (2 83))
            (do_s)
发表于 2022-5-27 11:24:16 | 显示全部楼层
楼主的工具 总是那么实用  都是精品
发表于 2022-5-27 17:38:31 | 显示全部楼层
支持,收藏,學習。
发表于 2022-7-31 08:02:51 来自手机 | 显示全部楼层
支持支持,太好用了
发表于 2022-9-24 20:37:00 | 显示全部楼层
非常好用!谢谢分享
GMT+8, 2026-1-12 07:20 , Processed in 0.155445 second(s), 19 queries , Gzip On.
