查看: 2965|回复: 3
(列表框设计)练习出错,帮忙看下哪里出错了
发表于 2011-12-26 16:48:53 | 显示全部楼层 |阅读模式
(defun c:dia7b()
  (setvar "cmdecho" 0)
  (setq word_list '("平面图" "立体图" "总经理室" "楼梯阁" "弹簧" "传真机" "教育中心" "规格表"))
  (chk_style)
  (dcl_dia7b)
  (prin1)
(defun dcl_dia7b()
  (setq dcl_id (load_dialog "dia7b"))
  (new_dialog "dia7b" dcl_id)
  (show_list "klist" word_list)
  (set_tile "klist" "4")
  (sub_klist1 "1")
  (action_tile "klist" "(sub_klist1 $value)")
  (action_tile "accept" "(ok_dia7b)(done_dialog 1)")
  (setq dd (start_dialog))
  (if (= dd 1)
      (setvar "cmdecho" 1)
      (command "text" pause pause 0 wordstr)
(defun show_list(key newlist)
  (start_list key)
  (mapcar 'add_list newlist)
  (end_list)
(defun sub_klist1(vvs)
  (setq oldstr (get_tile "wordstr"));没有数据
  (setq newstr (nth (atoi vvs) word_list))
  (set_tile "wordstr" (strcat (oldstr newstr)));提示这里出错
(defun ok_dia7b()
  (setq wordstr(strcase (get_tile "wordstr")))
(defun chk_style()
  (setq chksty (tblsearch "style" "kk"))
  (if (null chksty)
    (command "_style" "kk" "黑体" "" "" "" "" "" )
  (if (null chklay)
    (command "_layer" "m" "txt" "c" "3" "txt" "")
  (setvar "clayer" "txt")
  (setvar "textstyle" "kk")
对话框文件:
dia7b:dialog{
label="列表框的专家词库范例";
:list_box{
  label="常用词库选单";
  key="klist";
  width=30;
  height=10;
:edit_box{
  label="词库";
  key="wordstr";
  spacer_1;
  ok_cancel;
该贴已经同步到 mmh1的微博
 楼主| 发表于 2011-12-26 18:58:30 | 显示全部楼层
(set_tile "wordstr" (strcat (oldstr newstr)));此处多了个括号
(set_tile "wordstr" (strcat oldstr newstr))
发表于 2011-12-26 19:16:41 | 显示全部楼层
  (if (null oldstr) (setq oldstr ""))
  (set_tile "wordstr" (strcat oldstr newstr));提示这里出错
 楼主| 发表于 2011-12-26 20:29:28 | 显示全部楼层
  1. (defun c:dia7b()
  2.   (setvar "cmdecho" 0)
  3.   (setq word_list '("平面图" "立体图" "总经理室" "楼梯阁" "弹簧" "传真机" "教育中心" "规格表"))
  4.   (chk_style)
  5.   (dcl_dia7b)
  6.   (prompt "<<dia7b>>框设计......连续选")
  7.   )
  8. (defun dcl_dia7b()
  9.   (setq dcl_id (load_dialog "dia7b"))
  10.   (new_dialog "dia7b" dcl_id)
  11.   (show_list "klist" word_list)
  12.   (action_tile "klist" "(sub_klist1 $value)")
  13.   (action_tile "accept" "(ok_dia7b)(done_dialog 1)")
  14.   (setq dd (start_dialog))
  15.   (if (= dd 1)
  16.     (progn
  17.       (setvar "cmdecho" 1)
  18.       (command "text" pause pause 0 wordstr)
  19.       (setvar "cmdecho" 0)
  20.       )
  21.     )
  22.   )
  23. (defun show_list(key newlist)
  24.   (start_list key)
  25.   (mapcar 'add_list newlist)
  26.   (end_list)
  27.   )
  28. (defun sub_klist1(vvs)
  29.   (setq oldstr (get_tile "wordstr"))
  30.   (setq newstr (nth (atoi vvs) word_list))
  31.   (set_tile "wordstr" (strcat oldstr newstr))
  32.   )
  33. (defun ok_dia7b()
  34.   (setq wordstr(strcase (get_tile "wordstr")))
  35.   )
  36. (defun chk_style()
  37.   (setq chksty (tblsearch "style" "kk"))
  38.   (if (null chksty)
  39.     (command "_style" "kk" "黑体" "" "" "" "" "" "")
  40.     )
  41.   (if (null chklay)
  42.     (command "_layer" "m" "txt" "c" "3" "txt" "")
  43.     )
  44.   (setvar "clayer" "txt")
  45.   (setvar "textstyle" "kk")
  46.   )
找到答案了,这样就可以了
GMT+8, 2025-7-15 03:16 , Processed in 0.197616 second(s), 29 queries , Gzip On.
