楼主: 123523058
批量交点打断 支持多段线 <转帖>
发表于 2014-9-1 13:08:11 来自手机 | 显示全部楼层
好家伙,这么多
发表于 2015-10-30 10:53:57 | 显示全部楼层
lilq_78 发表于 2014-2-19 15:46
顶,但是矩形与矩形相交打断不行
对原程序243-266行代码进行了改进:
;;  Break many objects with a single object
(defun c:breakwobjects (/ cmd ss1 ss2)
  (defun ssredraw (ss mode / i num)
    (setq i -1)
    (while (setq ename (ssname ss (setq i (1+ i))))
      (redraw (ssname ss i) mode)
  (command ".undo" "begin")
  (setq cmd (getvar "CMDECHO"))
  (setvar "CMDECHO" 0)
  ;;  get objects to break
  (prompt "\nSelect object(s) to break & press enter: ")
  (if (and (setq ss1 (ssget '((0 . "LINE,ARC,SPLINE,LWPOLYLINE,POLYLINE,CIRCLE,ELLIPSE"))))
           (not (ssredraw ss1 3))
           (not (prompt "\n***  Select single object to break with:  ***"))
           (setq ss2 (ssget "+.:E:S" '((0 . "LINE,ARC,SPLINE,LWPOLYLINE,POLYLINE,CIRCLE,ELLIPSE"))))
           (not (ssredraw ss1 4))
    (break_with ss1 ss2 nil) ; ss2break ss2breakwith (flag nil = not to break with self)
  (setvar "CMDECHO" cmd)
  (command ".undo" "end")
;;  Break many objects with many object
(defun c:BreakWith (/ cmd ss1 ss2)
    (setq i -1)
  (setq xuanz nil)
  (prompt "\n选择要打断的直线或多线段,按回车确定: ")
  (if (and  (setq ss1
                      (ssget
                        '((0
                  xuanz (ssget "P" '((0 . "LWPOLYLINE") (70 . 1)));取出选中的闭合多段线,一般为矩形或多边形命令创建
                  flag1 (if (/= ss1 nil) T);判断选择集ss1是否非空
           (not
             (prompt
               "\n***  选择作为打断线的直线或多线段,按回车确定:  ***"
           (setq
             ss2 (ssget
                   '((0
             ssd  (ssredraw ss1 4);新增
             flag2 (if (/= ss2 nil) T);判断选择集ss2是否非空
           ;(not (ssredraw ss1 4))把该语句放在上面的setq语句群里,避免ss2为nil时本句不被执行的意外情况
      (if(/= xuanz nil)
      (setq snum -1)
      (repeat (SSLENGTH xuanz)
        (setq a (entget (ssname xuanz (setq snum (+ 1 snum)))));取出xuanz中的每个闭合多线段
        (setq num (cdr (assoc 90 a)))        ;多线段顶点数量
        (setq pnum (- (length a) (length (member (assoc 10 a) a))))
                                        ;pnum为多线段第一个顶点坐标子列表所在项数(组码10)
        (setq qdlst (PARTLIST1 pnum (+ pnum 4) a))
        ;第一个端点列表
        (setq tou (PartList1 0 (- (length a) 2) a))
        ;原列表去掉最后一个元素后的新列表
        (setq zhong (append tou qdlst))
        ;新列表插入第一个端点坐标
        (setq wei (nth (- (length a) 1) a))
        ;保存原列表最后一个元素
        (setq a (append zhong (list wei)))
        ;加入原列表最后一个元素
        (setq a (subst (cons 70 0) (assoc 70 a) a))
        ;将闭合多线段改为非闭合多线段
        (setq a (subst (cons 90 (+ num 1)) (assoc 90 a) a))
        ;修改多线段顶点个数
        (entmod a)
其中用到了黄老师提供的函数:
;截取部分列表子函数
(defun PartList1 (from to lst / I L)
  (setq i -1)
  (foreach x lst
    (setq i (1+ i))
    (cond ((and (>= i from) (<= i to)) (setq l (cons x l))))
  (REVERSE l)
发表于 2015-10-30 10:54:36 | 显示全部楼层
顶,但是矩形与矩形相交打断不行
    (setq i -1)
  (setq xuanz nil)
  (if (and  (setq ss1
                      (ssget
                        '((0
           (not
             (prompt
           (setq
             ss2 (ssget
                   '((0
      (if(/= xuanz nil)
      (setq snum -1)
        ;第一个端点列表
        ;原列表去掉最后一个元素后的新列表
        ;新列表插入第一个端点坐标
        ;保存原列表最后一个元素
        ;加入原列表最后一个元素
        ;将闭合多线段改为非闭合多线段
        ;修改多线段顶点个数
        (entmod a)
其中用到了自贡黄明儒老师发表的函数:
;截取部分列表子函数
  (setq i -1)
  (foreach x lst
    (setq i (1+ i))
  (REVERSE l)
guosheyang + 1 赞一个!
发表于 2016-3-12 02:17:26 | 显示全部楼层
很强大,很好,支持下!
发表于 2018-3-28 01:18:56 | 显示全部楼层
谢谢楼主分享
发表于 2018-8-21 11:11:53 | 显示全部楼层
学习一下啊!!!!!!!!!!!!
发表于 2020-2-29 18:56:02 | 显示全部楼层
非常好的功能,谢谢
GMT+8, 2026-1-16 06:33 , Processed in 0.151716 second(s), 20 queries , Gzip On.
