楼主: lz123456
怎样把TEXT文字转换成ATTDEF定义的属性
发表于 2022-8-27 12:29:14 | 显示全部楼层
psdcdr 发表于 2012-6-4 09:28
忘记在哪里找到的,一起分享下,
祝愿所有找LSP的朋友,都能得到答案!
这个程序有效,感谢分享
发表于 2022-8-29 07:57:42 | 显示全部楼层
lxl217114 发表于 2022-8-27 12:29
这个程序有效,感谢分享
(DEFUN C:TEXT2ATT (/ SS1 N TXTENT AA A1 A73 LST_210 LST_10)
  (VL-CMDF "_.undo" "_group")
  (SETVAR "blipmode" 0)
  (PRINC "\n选择TEXT文本对象: ")
  (setq SS1 (SSGET '((0 . "TEXT"))))
  (VL-CMDF "_.UCS" "W")
  (setq N 0)
  (REPEAT (SSLENGTH SS1)
    (setq TXTENT (SSNAME SS1 N))
    (setq LST_210 (APPEND LST_210 (LIST (ASSOC 210 (ENTGET TXTENT)))))
    (setq LST_10 (APPEND LST_10 (LIST (ASSOC 10 (ENTGET TXTENT)))))
    (setq AA (MEMBER '(100 . "AcDbEntity") (ENTGET TXTENT)))
    (setq A73 (CDR (ASSOC 73 AA)))
    (setq A1 (CDR (ASSOC 1 AA)))
    (ENTMAKE
      (APPEND '((0 . "ATTDEF"))
              (REVERSE (CDDR (REVERSE AA)))
              '((100 . "AcDbAttributeDefinition") (70 . 8))
              (LIST (CONS 74 A73) (CONS 3 A1) (CONS 2 A1))
    (setq N (1+ N))
  (VL-CMDF "_.erase" SS1 "")
  (VL-CMDF "_.UCS" "P")
发表于 2022-8-29 09:37:35 | 显示全部楼层
  (SET ...
谢谢盛老师
发表于 2022-12-8 07:32:02 | 显示全部楼层
忘记在哪里找到的,一起分享下,
祝愿所有找LSP的朋友,都能得到答案!
非常感谢你的分享
发表于 2022-12-8 11:24:20 | 显示全部楼层
试试这个
  1. (DEFUN C:TXT2ATT (/ SS1 N TXTENT AA A1 A73 LST_210 LST_10)
  2.   (VL-CMDF "_.undo" "_group")
  3.   (SETVAR "blipmode" 0)
  4.   (PRINC "\n选择TEXT文本对象: ")
  5.   (setq SS1 (SSGET '((0 . "TEXT"))))
  6.   (VL-CMDF "_.UCS" "W")
  7.   (setq N 0)
  8.   (REPEAT (SSLENGTH SS1)
  9.     (setq TXTENT (SSNAME SS1 N))
  10.     (setq LST_210 (APPEND LST_210 (LIST (ASSOC 210 (ENTGET TXTENT)))))
  11.     (setq LST_10 (APPEND LST_10 (LIST (ASSOC 10 (ENTGET TXTENT)))))
  12.     (setq AA (MEMBER '(100 . "AcDbEntity") (ENTGET TXTENT)))
  13.     (setq A73 (CDR (ASSOC 73 AA)))
  14.     (setq A1 (CDR (ASSOC 1 AA)))
  15.     (ENTMAKE
  16.       (APPEND '((0 . "ATTDEF"))
  17.               (REVERSE (CDDR (REVERSE AA)))
  18.               '((100 . "AcDbAttributeDefinition") (70 . 8))
  19.               (LIST (CONS 74 A73) (CONS 3 A1) (CONS 2 A1))
  20.       )
  21.     )
  22.     (setq N (1+ N))
  23.   )
  24.   (VL-CMDF "_.erase" SS1 "")
  25.   (VL-CMDF "_.UCS" "P")
  26. )
发表于 2023-6-6 11:06:55 | 显示全部楼层
忘记在哪里找到的,一起分享下,
祝愿所有找LSP的朋友,都能得到答案!
感谢分享,刚好有这方面的需求。
发表于 2023-6-11 15:52:05 | 显示全部楼层
  (SET ...
普通字转属性字程序有了,但属性字转普通字还没有
目前在论坛只找到一个如下    但这个没处理好文字对正问题,希望有高手改成保留原有校正等属性,只转换就好了
;; 属性转文字
(defun C:TAG2TXT ()
   (setq sset (ssget '((0 . "ATTDEF"))))
   (setq num (sslength sset) itm 0)
   (while (< itm num)
     (setq hnd (ssname sset itm))
     (setq ent (entget hnd))
     (setq new '((0 . "TEXT")))
     (setq new (append new (list (cons 1 (cdr (assoc 2 ent))))))
     (setq dolst (list 7 8 10 11 39 40 41 50 51 62 71 72 73))
     (foreach grp dolst
       (setq addto (assoc grp ent))
       (if (/= addto nil)
         (setq new (append new (list (assoc grp ent))))
     (entdel hnd)
     (entmake new)
     (setq itm (1+ itm))
推荐楼层的可以,文字在原位置; http://bbs.mjtd.com/forum.php?mod=redirect&goto=findpost&ptid=93928&pid=530556&fromuid=7332555  发表于 2025-4-16 13:06
发表于 2024-5-9 17:13:36 | 显示全部楼层
有用,想找这个程序
GMT+8, 2026-1-14 07:13 , Processed in 0.171701 second(s), 20 queries , Gzip On.
