- 积分
- 4986
- 明经币
- 个
- 注册时间
- 2004-6-16
- 在线时间
- 小时
- 威望
- 金钱
- 个
- 贡献
- 激情
发表于 2012-8-17 08:26:53
显示全部楼层
如果是这种方式,可以通过面域求解,以下简单写了个示意;
您可以根据需要自己修改调整下,比如可以采用人工控制是否采用面域算法(例中采用了图元数大于10为界)
 - (defun c:test (/ ss ssen wk a0 l0 a1 l1 str del l p h z en ent is ptl c pt en ssobj )
- ;;by GSLS(SS) 2012-8-14
- ;;图形面积相减并设置密度和厚度,输出文字
- (if (and (setq ss (ssget '((0 . "LWPOLYLINE,ELLIPSE,CIRCLE,SPLINE,LINE,ARC")))) ;_选择对象
- (setq ssen (ss2lst ss nil)))
- (progn
- (if (< (length ssen) 10) ;_如果对象数量多于10 按面域计算,这里您可以自己设定
- (if (setq
- ssen
- (vl-remove-if-not
- (function
- (lambda (x)
- (or (vlax-curve-isclosed x)
- (equal (vlax-curve-getstartpoint x)
- (vlax-curve-getendpoint x)
- 1e-8))))
- ssen)) ;_过滤非封闭曲线
- (progn
- (setq ssen
- (mapcar
- (function
- (lambda (x / l)
- (setq l (SS:ClosedCurve:GetPoints x 10))
- (if (equal (car l) (last l) 1e-8)
- (setq l (cdr l)))
- (list (vlax-curve-getarea x) l)))
- ssen)) ;_计算曲线面积和坐标表
- (setq ssen
- (vl-sort ssen
- (function (lambda (e1 e2)
- (> (car e1) (car e2)))))) ;_排序
- (setq wk (car ssen)
- ssen (cdr ssen)
- a0 (car wk)
- l0 (cadr wk))
- ;_减法计算
- (if ssen
- (foreach a ssen
- (setq a1 (car a)
- l1 (cadr a))
- (if
- (not (vl-some
- (function (lambda (x)
- (< (pipl? x l0 1e-8) 0)))
- l1))
- (setq a0 (- a0 a1)))))
- ;_if
- ) ;_progn
- (princ "\n选择对象类型错误,未包含封闭曲线。")
- ) ;_if
- (progn
- (setq en (entlast))
- (if (not (vl-catch-all-error-p
- (vl-catch-all-apply
- (function
- vl-cmdf)
- (list
- "_Region"
- ss ""))))
- (progn
- (setq ssen nil)
- (while (setq en (entnext en))
- (setq ssen (cons en ssen)))
- (setq ssobj (mapcar 'vlax-ename->vla-object ssen))
- (setq ssobj
- (vl-remove-if-not
- (eq (vla-get-objectname x)
- "AcDbRegion")))
- ssobj))
- (setq
- ssobj (vl-sort
- ssobj
- (> (vla-get-area e1)
- (vla-get-area e2)))))) (while (cadr ssobj)
- (vla-boolean
- (car ssobj)
- acSubtraction
- (cadr ssobj)
- (setq ssobj (cons (car ssobj) (cddr ssobj)))
- (setq a0 (vla-get-area (car ssobj)))
- (vl-cmdf "_EXPLODE"
- (vlax-vla-object->ename (car ssobj)))
- (if
- (and
- a0
- (not (minusp a0))
- (not (prompt
- "\n输入密度kg/m^3和厚度mm(空格或分号逗号隔开):"))
- (setq str (lm:getstring "7850 20"))
- (cond ((wcmatch str "* *")
- (setq del " "))
- ((wcmatch str "*;*")
- (setq del ";"))
- ((wcmatch str ",")
- ((setq del "-")))
- (setq l (mapcar 'atof (string->strlst str del)))
- (setq p (car l))
- (setq h (cadr l))
- ) ;_条件输入
- (progn
- (setq z (* a0 h p 1e-9))
- (setq str (strcat (rtos z 2 3) " kg"))
- (setq en (my_entsel "\n选择要修改的文字对象或点:"
- (list (cons 0 "TEXT"))
- nil))
- (setq p (car en))
- (if (cadr en)
- (entmod (setq ent (entget (cadr en))
- ent (subst (cons 1 str) (assoc 1 ent) ent)))
- (if (and (setq en
- (entmakex (list (cons 0 "TEXT")
- (cons 1 str) ;_文字内容
- (cons 10 (trans p 1 0)) ;_插入点
- (cons 72 0) ;_
- (cons 73 1) ;_72 73对正样式,左对齐
- (cons 62 256) ;_文字颜色,随层
- (cons 40 3.) ;_文字高度
- (cons 41 0.7) ;_文字宽度
- (cons 50 0.0) ;_文字旋转角度
- (cons 7 "STANDARD") ;_文字样式
- (setq ent (entget en))
- (setq is t))
- (while is
- (setq ptl (grread t 15 0))
- (setq c (car ptl))
- (cond
- ((= c 5)
- (setq pt (cadr ptl))
- (setq ent (subst (cons 11 pt)
- (assoc 11 ent)
- ent))
- (entmod ent)
- (entupd en)
- ((= c 3)
- (setq is nil)
- ) ;_cond
- ) ;_while
- ) ;_if
- ) ;_if
- (princ (strcat "\n面积与密度换算重量为" str "。"))
- ) ;_progn
- (princ "\n未输入密度和厚度。")
- (princ "\n未选择对象,请重新执行命令。")
- ) ;_if
- (princ)
- ) ;_defun
- ;;;配套函数;;;转换选择集为表
- (defun ss2lst (ss vla / a e i)
- (if (= (type ss) (quote PICKSET))
- (progn
- (setq i -1)
- (while (setq e (ssname ss (setq i (1+ i))))
- (if vla
- (setq e (vlax-ename->vla-object e))
- nil)
- (setq a (cons e a))))
- nil))
- ;;;判断点是否在封闭多边形内 .
- ;;;Function : judge a point location with polygon
- ;;;Arg : pt -- a point
- ;;; pts -- points of polygon
- ;;; eps -- allowance
- ;;;return :
- ;;; -1 -- out of polygon , 0 -- at , 1 -- in
- (defun pipl? (pt pts eps / is at a)
- ;; by 狂刀
- ;; Edit by GSLS(SS) 2011.03.28
- ;; Solved the problem : if a point at the given polygon , it perhap return T or NIL .
- (if (vl-some (function (lambda (x) (equal x pt eps))) pts)
- 0
- (progn (setq is
- (equal
- PI
- (abs
- (apply
- (function +)
- (mapcar
- (function (lambda (x y / a)
- (setq a
- (rem (- (angle pt x) (angle pt y))
- PI))
- (if (equal (+ (distance pt x)
- (distance pt y))
- (distance x y)
- Eps)
- (setq at T))
- a))
- (cons (last pts) pts)
- pts)))
- eps))
- (cond (at 0)
- (is 1)
- (T -1)))))
- ;;字符串转为表
- (defun string->strlst (str del / lst a s1 cha pos i)
- (setq s1 ""
- i 0
- a (ascii del))
- (while (setq pos (vl-string-position a str i))
- (setq s1 (substr str (1+ i) (- pos i)))
- (if (/= s1 "")
- (setq lst (cons s1 lst)))
- (setq i (1+ pos)))
- (setq s1 (substr str (1+ i)))
- (if (/= s1 "")
- (reverse lst))
- ;;封闭曲线取点函数
- (defun SS:ClosedCurve:GetPoints (en acc / ent et)
- ;;by GSLS(SS)
- (setq
- ent (entget en)
- et (cdr (assoc 0 ent)))
- (cond
- ((= et "LWPOLYLINE")
- ((lambda (/ a b vetex bu p1 p2 l r ang an1 N)
- (while (setq ent (member (assoc 10 ent) ent))
- (setq b (cons (cdar ent) b)
- ent (member (assoc 42 ent) ent)
- b (cons (cdar ent) b)
- ent (cdr ent)
- vetex (cons b vetex)
- b nil))
- (while vetex
- (setq a (car vetex)
- vetex (cdr vetex)
- bu (car a)
- p1 (cadr a))
- (if l
- (setq p2 (car l))
- (setq p2 (cadr (last vetex))))
- (if (equal bu 0 1e-6)
- (setq l (cons p1 l))
- (progn
- (setq ang (* 2 (atan bu))
- r (/ (distance p1 p2) (* 2 (sin ang)))
- c (polar p1 (+ (angle p1 p2) (- (/ pi 2) ang)) r)
- r (abs r)
- ang (abs (* ang 2.0))
- N (abs (fix (/ ang 0.0174532925199433)))
- N (min N (1+ Acc)))
- (if (= N 0)
- (progn
- (setq an1 (/ ang N)
- ang (angle c p2))
- (if (not (minusp bu))
- (setq an1 (- an1)))
- (repeat (1- N)
- (setq ang (+ ang an1)
- l (cons (polar c ang r) l)))
- (setq l (cons p1 l)))))))
- l)))
- ((= et "CIRCLE")
- ((lambda (c R / sa l)
- (setq sa 0.0)
- (repeat 180
- (setq l (cons (polar c sa R) l)
- sa (+ sa 0.0174532925199433)))
- (setq l (reverse l))
- (append
- l
- (mapcar
- (function
- (lambda (p)
- (mapcar (function +) c (mapcar (function -) c p))))
- l)))
- (cdr (assoc 10 ent))
- (cdr (assoc 40 ent))))
- ((= et "SPLINE")
- ((lambda (/ r _oce)
- (setq _oce (getvar "CMDECHO"))
- (setvar "CMDECHO" 0)
- (if (vl-catch-all-apply
- (function vl-cmdf)
- (list "_PEDIT"
- (vla-copy (vlax-ename->vla-object en))
- acc
- (progn
- (setq l (ss-assoc 10 (entget (setq r (entlast)))))
- (if (vlax-curve-isClosed r)
- (setq l (append l (list (car l)))))
- (entdel r)))
- (setvar "CMDECHO" _oce)
- l)))
- ((= et "ELLIPSE")
- ((lambda (/ e l _os)
- (setq _os (getvar "OSMODE"))
- (setvar "OSMODE" 0)
- (function vla-offset)
- (list (vlax-ename->vla-object en) 0.1))
- (setq e (entlast))
- (list (vlax-ename->vla-object (entlast)) -0.1))
- (entdel e)
- (setq l (ss-assoc 10 (entget e)))
- (entdel e)
- (setvar "OSMODE" _os)
- l)))))
- ;;;by Lee Mac
- (defun LM:GetString (#Default / dcTag result)
- (cond ((<= (setq dcTag (load_dialog "ACAD")) 0))
- ((not (new_dialog "acad_txtedit" dcTag)))
- (t
- (set_tile "text_edit" #Default)
- (action_tile
- "accept"
- "(setq result (get_tile "text_edit")) (done_dialog)")
- (action_tile "cancel" "(done_dialog)")
- (start_dialog)
- (unload_dialog dcTag)))
- result)
- ;; 【索引表查找】全部
- ;;;获取表中索引码相同的所有元素
- ;;;ss-assoc 最快
- (defun ss-assoc (a lst / b res)
- (while (setq b (assoc a lst))
- (setq lst (cdr (member b lst))
- res (cons (cdr b) res)))
- (reverse res))
- (defun my_entsel
- (STR FILTER PRO / PT SS_NAME SS old_modemacro)
- (setq old_modemacro (getvar "MODEMACRO"))
- (if (/= (type STR) (quote STR))
- (progn
- (princ "\n变量类型不对,STR应为字符串。\n")
- (eval NIL))
- (progn
- (if (/= (type FILTER) (quote list))
- (progn
- (princ "\n变量类型不对,FILTER应为表。\n")
- (eval NIL))
- (progn
- (princ STR)
- (setvar "MODEMACRO" STR) ;_这里添加选择修改
- (setq PT (grread t 4 2)
- is_go_on t)
- (while (and (/= 3 (car PT))
- (/= 11 (car PT))
- (/= 25 (car pt))
- is_go_on)
- (cond
- ((and (= 2 (car pt))
- (or (= 13 (cadr pt)) (= 32 (cadr pt)))) ;_Enter,Space.
- (setq is_go_on nil))
- (or (= 115 (cadr pt)) (= 83 (cadr pt)))) ;_S set arg.
- (eval pro)
- (princ STR))
- ((and (= 5 (car PT)) (vl-consp (cadr PT)))
- (setq SS (ssget (cadr PT) FILTER))
- (if SS_NAME
- (redraw SS_NAME 4))
- (setq SS_NAME NIL)
- (if SS
- (progn
- (setq SS_NAME (ssname SS 0))
- (redraw SS_NAME 3))
- (setvar "MODEMACRO" old_modemacro)))
- ) ;_cond
- (setq PT (grread t 4 2))
- ) ;_while
- (if (and (/= 11 (car pt)) (/= 25 (car pt)))
- (progn
- (setq PT (cadr PT))
- (setq SS (ssget PT FILTER))
- (setvar "LASTPOINT" PT)
- (if SS_NAME
- (if SS
- (progn
- (list (trans PT 1 0) SS_NAME))
- (list (trans PT 1 0))))
- (if ss_name
- (redraw ss_name 4))))))))
