楼主: 自贡黄明儒
[函数] 常用函数.lsp
 楼主| 发表于 2012-10-24 15:36:53 | 显示全部楼层
;;154.7 [功能] 复制非打开文件的块至本图
;;154.8 [功能] 复制非打开文件的特定块至本图
;;154.9 [功能] 复制特定文件的块至本图(不论打开或者非打开)
  1. ;;154.7 [功能] 复制非打开文件的块至本图
  2. ;;(Odbx-copyblocks 文件名)
  3. ;;(Odbx-copyblocks "D:\\DrawingA.dwg"),之后输入命令i,就可以看到DrawingA的块均在本图中了
  4. (defun Odbx-copyblocks (DwgName / DBXBLOCKS DBXDOC NUM)
  5.   (setq        dbxDoc (vla-GetInterfaceObject
  6.                  (vlax-get-acad-object)
  7.                  (GetObjectDBXVer)
  8.                )
  9.   )
  10.   (vla-open dbxDoc DwgName)                ;不能打开.dxf文件,返回nil
  11.   (setq DBXBLOCKS (vla-get-blocks dbxDoc))
  12.   (vlax-for BLK        DBXBLOCKS
  13.     (if        (and (not (wcmatch (substr (vla-get-name BLK) 1 1) "`*"))
  14.              (= (vla-get-isxref BLK) :vlax-false)
  15.         )                                ;去除系统块、匿名块和参照类对象
  16.       (setq namelst (append namelst (list (vla-get-name BLK))))
  17.     )
  18.   )
  19.   (foreach name        namelst
  20.     (setq num (vla-item DBXBLOCKS name))
  21.     (vla-copyobjects
  22.       dbxDoc
  23.       (vlax-safearray-fill
  24.         (vlax-make-safearray vlax-vbobject '(0 . 0))
  25.         (list num)
  26.       )
  27.       (vla-get-modelspace
  28.         (vla-get-activedocument (vlax-get-acad-object))
  29.       )
  30.     )
  31.   )
  32.   (if dbxDoc
  33.     (vlax-release-object dbxDoc)
  34.   )
  35. )
;;示例(CopyBlock "D:\\DrawingA.dwg" "ccd1"),之后输入命令i,就可以看到DrawingA的"ccd1"块在本图中了
;; COPYBLOCK.LSP  Copyright ?999  Tony Tanzillo
;;   http://www.caddzone.com
;;   tony.tanzillo@caddzone.com
(defun CopyBlock (DwgName BlkName / *ACAD* BLOCKS DBXDOC NUM)
  (setq *acad* (vlax-get-acad-object))
  (setq blocks (vla-get-blocks (vla-get-ActiveDocument *acad*)))
  (setq dbxDoc (vla-GetInterfaceObject *acad* (GetObjectDBXVer)))
  (setq num (vla-item (vla-get-blocks dbxDoc) BlkName))
  (vla-CopyObjects
    dbxDoc
        vlax-vbObject
        '(0 . 0)
      (list num)
    blocks
  (vla-item blocks BlkName)
;;本程序将选择一个文件,然后将其下的块均拷贝到本图中,用命令i就可以插入这些块了
(defun B2CurDrawing (/ *ACAD* *DOC* *DOCS* FNAME FULLNAME LST)
  (defun Open-copyblocks (fname / BLOCKS DOC DOCBLOCKS NAMELST NUM)
    (setq blocks (vla-get-blocks *DOC*))
    (setq Doc (vla-item        *DOCS*
                        (strcat        (vl-filename-base fname)
                                (vl-filename-extension fname)
    (setq DocBLOCKS (vla-get-blocks Doc))
    (vlax-for BLK DocBLOCKS
          )                                ;去除系统块、匿名块和参照类对象
      (setq num (vla-item DocBLOCKS name))
      (vla-CopyObjects
        Doc
            vlax-vbObject
            '(0 . 0)
          (list num)
        blocks
    (vlax-release-object doc)
  (setq        *ACAD* (vlax-get-acad-object)
        *DOC*  (vla-get-ActiveDocument *acad*)
        *DOCS* (vla-get-Documents *ACAD*)
  (setq fullname (vla-get-fullname *DOC*))
  ;;打开文件列表
  (vlax-for doc        *DOCS*
    (setq
      lst (cons        (if (/= (setq fname (vla-get-fullname doc)) "")
                  fname
                  (vla-get-name doc)
                lst
  (setq        fname (getfiled        "选择DWG文件"
                        (strcat (vl-filename-directory fullname) "\\")
                        "DWG"
                        0
  (cond        ((and fname (member fname lst) (not (equal fullname fname)))
         (Open-copyblocks fname)
        ((and fname (not (member fname lst)))
         (Odbx-copyblocks fname)
        (T nil)
这个功能强!  发表于 2012-10-24 18:22
发表于 2012-10-24 16:00:22 | 显示全部楼层
还有多少?
谁知道呢,暂时就搞了这么多。  发表于 2012-10-24 17:01
发表于 2012-10-24 16:43:12 | 显示全部楼层
为什么不在一楼更新呢?差点没找到。。。
看到了吗,有人很不高兴我在一楼更新  发表于 2012-10-24 17:00
发表于 2012-10-24 17:00:12 | 显示全部楼层
学习一下
发表于 2012-10-24 17:49:13 | 显示全部楼层
没有问题的,在一楼更新附件,下过的就不会重复收币,小菜选择易就是最经典的例子
发表于 2012-10-24 22:36:32 | 显示全部楼层
经典,经典
发表于 2012-10-25 06:55:37 | 显示全部楼层
建议楼主可在一楼统一更新,
这样小弟才比较不会有遗漏,赞啦!
发表于 2012-10-25 20:29:59 | 显示全部楼层
支持楼主l希望楼主多发精品好帖.....
发表于 2012-10-26 00:11:19 | 显示全部楼层
很实用的函数,谢谢分享。
发表于 2012-10-26 08:26:41 | 显示全部楼层
精彩贴,差点被遗漏!谢谢大虾们!
GMT+8, 2026-1-24 14:17 , Processed in 1.622995 second(s), 20 queries , Gzip On.
