查看: 2952|回复: 7
[已解答] 出错,求帮助。管道用已知2点,求2点距离,坡度,并标注在图纸上,
发表于 2013-7-16 16:31:27 | 显示全部楼层 |阅读模式
(defun c:YS1 ()
(setvar "CMDECHO" 0)
(if (and
      (setq pt1 (getpoint "\nFirst Point 点一 :"))
      (setq pt2 (getpoint pt1 "\nSecond Point 点二 :"))
  (setq xx (- (car pt2) (car pt1))
        yy (- (cadr pt2) (cadr pt1))
        num (/ yy 1.0 xx)
str (rtos (* 100 num) 2 1)
  (setq dst (distance pt1 pt2)
        str1 (rtos (dst 2 1))
        dtt (strcat "DN300 L="str1 "m i="str "%")
        a1 (angle pt1 pt2)
        a2 (* (/ a1 pi) 180)
        ptt (polar pt1 a1 (/ dst 2))
     (command "text" "j" "bc" ptt 2.5 a2 dtt)
求高手帮我看看
发表于 2013-7-16 16:58:40 | 显示全部楼层
  1. (defun c:ys1 ()
  2.   (setvar "CMDECHO" 0)
  3.   (if (and
  4.         (setq pt1 (getpoint "\nFirst Point ?? :"))
  5.         (setq pt2 (getpoint pt1 "\nSecond Point ?? :"))
  6.       )
  7.     (progn
  8.       (setq xx        (- (car pt2) (car pt1))
  9.             yy        (- (cadr pt2) (cadr pt1))
  10.             num        (/ yy 1.0 xx)
  11.             str        (rtos (* 100 num) 2 1)
  12.       )
  13.       (setq dst         (distance pt1 pt2)
  14.             str1 (rtos dst 2 1) ;; FIX 1
  15.             dtt         (strcat "DN300 L=" str1 "m i=" str "%")
  16.             a1         (angle pt1 pt2)
  17.             a2         (* (/ a1 pi) 180)
  18.             ptt         (polar pt1 a1 (/ dst 2))
  19.       )
  20.       (command "text" "j" "bc" ptt 2.5 a2 dtt) ;; FIX2
  21.     )
  22.   )
  23.   (princ)
  24. )
FIX1 多余的括号删除
FIX2 command放置的位置有误
tranney + 1
发表于 2013-7-16 17:09:24 | 显示全部楼层
首先声明一下,我不是高手。现将程序修改如下:
(defun c:YS1 ()
(if (and
        num (/ yy 1.0 xx)
        str1 (rtos dst 2 1)
        a1 (angle pt1 pt2)
发表于 2013-7-16 17:21:12 | 显示全部楼层
楼上两位正解
 楼主| 发表于 2013-7-16 17:22:15 | 显示全部楼层
谢谢各位大哥热心帮忙
发表于 2013-7-30 15:24:51 | 显示全部楼层
呵呵,想不到我也才参与过呀
发表于 2024-1-4 21:13:25 | 显示全部楼层
vectra 发表于 2013-7-16 16:58
FIX1 多余的括号删除
FIX2 command放置的位置有误
前辈好,请问能不能实现动态确定文字标注位置
发表于 2025-1-21 19:48:28 | 显示全部楼层
好代码,学习一下喽
GMT+8, 2026-1-22 17:19 , Processed in 1.003573 second(s), 31 queries , Gzip On.
