查看: 9291|回复: 20
[已解答] 开心版主的改图层颜色程序,对天正图元不管用,求助~
发表于 2014-9-15 08:50:17 | 显示全部楼层 |阅读模式
1明经币
;建筑图层改色
(defun c:GS()
  (vl-load-com)(KX-LAY-COL "0" 7)
(KX-LAY-COL "厨卫设备" 252)
(KX-LAY-COL "家具" 252)
(KX-LAY-COL "空调洞" 252)
(KX-LAY-COL "预留孔洞" 252)
(KX-LAY-COL "空调" 252)
(KX-LAY-COL "WALL" 140)
(KX-LAY-COL "PUB_DIM" 3)
(KX-LAY-COL "PUB_TEXT" 255)
(KX-LAY-COL "STAIR" 2)
(PRINC)
CAD提示:错误: 此类型的 LISP 值不能强制转换成 VARIANT: 252
原帖子在这里 http://bbs.mjtd.com/thread-93873-1-1.html
最佳答案
查看完整内容
天正实体改图层颜色之后可能要re重新生成图形才能显示最新的颜色 http://bbs.mjtd.com/thread-111059-1-1.html 这里还有个快速改图层颜色的小程序 支持天正
发表于 2014-9-15 08:50:18 | 显示全部楼层
  1. ;改图层颜色子程序。参数:图层、颜色 例:(GL:LayCol "PUB_DIM" 3)
  2. (defun GL:LayCol (lay col / acaddoc acadobj layobj vlay)
  3.   (setq AcadObj (vlax-get-Acad-object)
  4.         AcadDoc (vla-get-ActiveDocument AcadObj)
  5.         LayObj (vla-get-layers AcadDoc)
  6.   )
  7.   (setq vlay (vla-item LayObj lay))    ; 转为VL图层名
  8.   (vla-put-color vlay col)               ; 改图层颜色
  9. )
发表于 2014-9-15 17:47:37 | 显示全部楼层
源程序贴上来改改看
 楼主| 发表于 2014-9-15 20:00:24 | 显示全部楼层
hnfsf 发表于 2014-9-15 17:47
源程序贴上来改改看
源程序开心版主是收费的~纠结,我只贴出关键部分吧,开心的大作有3个独立的程序,我针对实际遇到的问题只贴出其中1个(请开心版主海涵):
;功能:取得实体DXF组码对应的值。参数:DXF为组码 ;ent为实体名。;返回值:DXF组码值表
(defun KX-get-dxf (DXF ent)
    (cond ((= (type ent) 'ename)
            (cdr (assoc DXF (entget ent)))
          ((= (type ent) 'list)
           (cdr (assoc DXF ent))
;;功能:更换图元。参数:sname为实体名;DXF为组码;newvalue为新值  ;返回值:新对象
(defun KX-SubUpd (sname DXF newvalue)
   (entmod
     (subst
       (cons DXF newvalue)
       (assoc DXF (entget sname))
       (entget sname)
(entupd sname)
;改变对象颜色 sname为实体名 col为颜色号
(defun KX-put-color(sname col)
      (vla-put-color (vlax-ename->vla-object sname) col)
(PRINC)
;批量匹配图层改色
;(KX-LAY-COL lname COL)  lname为层名  CO为颜色
(defun KX-LAY-COL (lname coL)
(if (setq newl (tblobjname "layer" lname))
     (KX-SubUpd newl 62 col)
    (if (SETQ ss (ssget "X" (list (cons 8 lname))))
          (setq X -1)
        (while (setq s1 (ssname ss (setq X (1+ X))))
           (KX-put-color s1 coL)
;程序一 (批量匹配图层改色)
(defun c:XX()
  (vl-load-com)
   (KX-LAY-COL "DOTE" 1)
   (KX-LAY-COL "DIM" 2)
   (KX-LAY-COL "WALL" 3)
(PRINC)
发表于 2014-9-20 19:59:03 | 显示全部楼层
楼主找到答案了吗?同求
 楼主| 发表于 2014-9-20 23:43:08 | 显示全部楼层
开心老大还不来看看吗?
发表于 2014-9-21 08:11:20 | 显示全部楼层
theisland 发表于 2014-9-15 20:00
源程序开心版主是收费的~纠结,我只贴出关键部分吧,开心的大作有3个独立的程序,我针对实际遇到的问题只 ...
天正的东东要用ARX编程来改。
发表于 2014-9-21 09:01:50 来自手机 | 显示全部楼层
chprop   ssget   c
发表于 2014-9-21 09:08:43 | 显示全部楼层
天正很多都是自定义实体,LISP办不打
 楼主| 发表于 2014-9-21 19:50:44 | 显示全部楼层
http://bbs.mjtd.com/thread-111059-1-1. ...
老大们都来了,好开心!你这个这么用?补充到开心版主 的程序里吗?链接里没有预先设置好的改色,我现在最需要的就是像开心版主那种预先设置好的改色方案
GMT+8, 2026-1-8 06:37 , Processed in 0.174718 second(s), 29 queries , Gzip On.
