查看: 1739|回复: 3
[已解答] 请问如何将文字样式修改程序
发表于 2014-9-19 12:26:49 | 显示全部楼层 |阅读模式
把CAD文档中的文字样式"mychina"转换成"standard"的程序,请大家指教,如何编写程序?
发表于 2014-9-19 13:43:59 | 显示全部楼层
更新组码7.
发表于 2014-9-19 14:09:11 | 显示全部楼层
  1. (defun c:tt()
  2.   (setq ss (ssget))
  3.   (setq        ssn (sslength ss))
  4.   (setq n 0)
  5.   (repeat ssn
  6.     (setq en(ssname ss n))
  7.     (setq ob (vlax-ename->vla-object en))
  8.     (vla-put-StyleName ob "standard")
  9.     (setq n (1+ n))
  10.     )
  11.   (print (strcat "共更新" (rtos ssn 2 0) "个对象"))
  12.   (princ)
  13.   )
发表于 2014-9-19 18:51:15 | 显示全部楼层
;修改文字的字体
(defun *error*(st)
  (princ (strcat "错误: " st))
(defun C:xgzt(/ test ss len n en1 a oldr newr ent nn)
  (setvar "CMDECHO" 0)
  (setq test T nn 0)
  (while test
    (setq ss (ssadd))
    (setq ss (ssget))
    (if (= nil ss)
      (setq test nil)
        (setq len (sslength ss))
        (setq n 1 s 1)
        (while (<= n len)
          (setq en1 (ssname ss (1- n)))
          (setq a (entget en1))
          (if  (= "TEXT" (cdr (assoc 0 a)))
              (if (= s 1)
                  (setq oldr (cdr (assoc 7 a)))
                  (setq newr (strcase (getstring (strcat "\n新字体 <" oldr ">:"))))
                  (if (= newr "") (setq newr oldr))
                  (setq s nil)
              (if (= (tblsearch "style" newr) nil)
                  (cond ((= newr "XW")
                          (command "STYLE" "xw" "txt" "0" ".8" "0" "n" "n" "n"))
                        ((= newr "HZ")
                          (command "STYLE" "hz" "txt,hztxt" "0" ".8" "0" "n" "n" "n"))
                        ((= newr "CHINA")
                          (command "STYLE" "china" "txt,china" "0" ".8" "0" "n" "n" "n"))
                        ((= newr "LM")
                          (command "STYLE" "lm" "complex" "0" ".8" "0" "n" "n" "n"))
                        (T (princ (strcat "\nPlease define style " newr " use STYLE command !")))
              (setq ent (subst (cons 7 newr) (assoc 7 a) a))
              (entmod ent)
              (setq nn (1+ nn))
GMT+8, 2026-1-3 08:02 , Processed in 0.195924 second(s), 30 queries , Gzip On.
