楼主: 纵横八方
[提问] 怎么在面板标题头上 加入 <日期+星期+当前时间>
发表于 2018-11-3 20:16:13 | 显示全部楼层
yaokui25 发表于 2018-11-3 18:36
(action_tile "accept"
    "(done_dialog)"
);action_tile
dear sir,
till not working
please explain with full code
发表于 2019-2-10 19:58:57 | 显示全部楼层
这是DCL不是OpenDCL吧
发表于 2019-11-20 09:44:09 | 显示全部楼层
你好,我试了一下,怎么没用呀?
发表于 2020-8-24 23:12:21 | 显示全部楼层
多谢大佬啊
发表于 2020-9-29 21:04:32 | 显示全部楼层
你好,请教一下,怎么在这个面板下边的帮助按钮旁边增加一个按钮,点击这个按钮就打开指定位置的其它vlx文件?
我加入下边这句之后,可以用快捷命令启动指定的程序,但是点击按钮没反应,按钮那个地方应该怎么写?
(defun c:***() (if (null c:***) (load "D:/***.VLX"))(c:***));打开其它程序
这个地方应该怎么写,才能让点击按钮也能够启动指定的程序?
   ":button{key = \"c:***\";label = \"批量打印\";}\n"
另一个问题,我加载了一个外部程序之后,加载第二个的话,
提示说“出现硬错误 ***
已达内部堆栈限制 (模拟)”
最后我想在左下角增加时间,应该怎么写,能说一下吗。我试了帖子里说的那些,都不出现时间,应该是我写的不对。
谢谢了
下边是源码
(defun Dcl-ButtonM (titl buttons flag / a b c)
   (defun strsplist (str / i)
     (if (setq i (vl-string-search " " str))
       (list (substr str 1 i)
                                 (vl-string-trim " " (substr str (+ 2 i)))
   (defun makedcl (str_lst / fileID dclHandle)
     (setq
                         dclfile (vl-filename-mktemp nil nil ".dcl")
                         fileID  (open dclfile "w")
     (cond
                         ((= (type str_lst) 'str)
                                 (write-line str_lst fileID)
                         ((= (type str_lst) 'list)
                                 (foreach n str_lst (write-line n fileID))
                 (close fileID)
                 (setq dclHandle (load_dialog dclfile))
         (setq
                 b (if flag
                                 ":column{label = \""
                                 (strcat
                                 ":spacer{ wide=1; fixed_width=true;} \n"
                                 ":row{label = \""
                 c (if flag
                                 ":row{label = \""
                 d '("ESC")
                 a (strcat (vl-string-translate
        "AB"
        (vl-filename-base (vl-filename-mktemp))
                                 ":dialog{label=\""
                                 titl
                                 "\";\n"
                                 b
                                 "\";\n"
   (foreach x buttons
     (if (listp x)
         (setq a (strcat a c (car x) "\";\n"))
         (foreach y (last x)
           (setq
                                                 b (strsplist y)
                                                 a (if b
        (strcat a
        ":button {key =\""
        (car b)
        "\";label=\""
        (last b)
        "\";}\n"
        (strcat a "spacer_0;\n")
                                                 d (if (/= (car b) nil)
        (cons (car b) d)
        d
         (setq a (strcat a "}\n"))
       (setq a (strcat a "spacer_0;\n"))
         (setq
                 d    (cdr (REVERSE d))
                 a    (strcat a
                                          ":text{key=\"str\";label=\"文字\";}"
                                          ":row{"
                                          ":spacer { width = 60; } "
                                          ":button{key = \"HLP\";label = \"帮助\";}\n"
                                          ":button{key=\"ESC\";label=\"取消\";is_cancel = true;}}}"
                 dcl  (makedcl a)
                 lst1 '()
                 i    1
   (foreach key d
     (setq
                         tx   (strcat "(action_tile \""
                                                  key
                                                  "\"\"(done_dialog "
                                                  (itoa i)
                         lst1 (cons tx lst1)
                         i    (1+ i)
   (new_dialog (substr a 1 8) dcl)
   (action_tile "ESC" "(done_dialog 0)")
   (action_tile "HLP" "(alert\"帮助\")")
   (eval (read (strcat "(progn" (apply 'strcat lst1) ")")))
   (setq ctl (start_dialog))
   (UNLOAD_DIALOG dcl)
   (vl-file-delete dclfile)
         (if (/= ctl 0)
     (eval (read (strcat "(c:" (nth (- ctl 1) d) ")")))
(defun c:tt (/ lst)
   (setq        lst '(
                         ("命令"
                                 ("0 改为0层  "
                         ("视口"
                                 ("ZZ 视口比例 "
  (Dcl-ButtonM "xx工具箱 " lst nil)
GMT+8, 2026-1-17 23:57 , Processed in 4.226371 second(s), 20 queries , Gzip On.
