楼主: l282027798
[提问] 如何删除list中,指定位置的元素,返回删除后的列表?
 楼主| 发表于 2018-11-13 11:21:46 | 显示全部楼层
fangmin723 发表于 2018-11-12 13:19
人家不喜欢vlisp函数,他认为需要加载(vl-load-com)
不是不喜欢,而是有时候加载会失败,而且懒得解决了。
发表于 2018-11-29 11:48:08 | 显示全部楼层
lisperado 发表于 2018-11-12 11:08
(defun nth_del (l n / i)
        (setq i 0)
        (vl-remove-if '(lambda (i)(= i n)) l)
Sorry for my bad, we needn't set i value ^^
  1. ( defun  nth_del  ( l n )
  2.         ( vl-remove-if  ' ( lambda ( i ) ( = i n ) )  l )
  3. )
发表于 2018-11-29 18:53:11 | 显示全部楼层
;try other list ^^
(nth_del '(9 8 7 6 5 4 3 2 1) 3) ;? nth 3 is 6
(setq lst '(1st B 2 "3" ) )
( nth_del lst 3 )
发表于 2018-12-2 17:05:20 | 显示全部楼层
Oh i see now. I miss-understood the question when translating from Chinese to my language. Tks you for point oues
发表于 2019-7-24 17:16:44 | 显示全部楼层
  1. (defun nth_del (lst n / i)
  2. (setq i -1)
  3. (vl-remove-if '(lambda (x) (= (setq i (1+ i)) n)) lst)
  4. )
GMT+8, 2026-1-19 04:04 , Processed in 0.136373 second(s), 19 queries , Gzip On.
