查看: 1033|回复: 4
[提问] 指北插件旋转线条后提取终点坐标并自动标注角度代码求助~
发表于 2024-9-8 00:14:33 | 显示全部楼层 |阅读模式
(defun c:ccc(/ pt1 pt2 pt3 pt4)
    (setq jd (getreal "\n角度"))
    (setq pt1 (getpoint "\n插入点") )
        (setq pt4 (mapcar '+ pt1 '(0 1000 0)) )
        (setq pt2 (mapcar '+ pt1 '(0 1000 0)) )
    (command "line" pt1 pt4 "")
    (setq ty1 (entlast))
    (setq ang (angle pt1 pt2))
    (setq jl (distance pt1 pt2))
    (setq pt3 (polar pt1 ang jl))
    (entmake (list '(0 . "LWPOLYLINE") '(100 . "AcDbEntity") '(100 . "AcDbPolyline") '(62 . 1) (cons 90 2) (cons 10 pt1) (cons 10 pt3)))
    (setq jd1 (- jd))
    (setq ty2 (entlast))
    (command "rotate" ty2 "" pt1 jd1)
        (command "rotate" ty1 ty2 "" pt1)
    (command pause)
        (setq ename (car (entsel))
            spt1 (vlax-curve-getstartpoint ename)
            ept1 (vlax-curve-getendpoint ename))
        (setq pz (mapcar '+ pt2 '(0 200 0)) )
        (setq jdjt2 (angle pt1 ept1)
          jljt (distance pt1 pz)
          pz (polar pt1 jdjt2 jljt))
    (command "-text" "j" "mc" pz "300" "" "N")
    (command "dimangular" pause pause (getpoint))
)a
以上代码能满足我的需求,但确定线条方向后需要点击(第一次点击)红色线条生成指北符号,再分别点击(第二、三次点击)红白线条后还得点击(第四次点击)选取角度标注的位置。虽然够用,却也稍显麻烦,请问怎么样减少这四次点击(选取)的步骤?
第一次点击跟(car (entsel)有关,但不知道怎么替代。尝试将白色为定义直线,红色定义为多段线,但也没有将选取的代码弄成功。
(command "line" (setq p1(getpoint "第一点:")) (setq p2(getpoint p1 "第二点:")) "")
(setq LN1 (entlast))
(command "line" (setq p3(getpoint "第三点:"))(setq p4(getpoint p3"第四点:")) "")
(setq LN2 (entlast))
(command "_dimangular" (list LN1 p1) (list LN2 p3) (mapcar   '(lambda(x y) (/(+ x y)2)) p1 p3))
此外,尝试用以上代码替代角度标注,但好像也不太行。
求各位大佬帮忙,谢谢~
发表于 2024-9-8 17:12:20 | 显示全部楼层
  1. (defun c:tt ()
  2.   "指北针"
  3.   (if (and (setq jd (getreal "\n角度: " ))
  4.            (setq p1 (getpoint "\n插入点: "))
  5.       )
  6.     (progn
  7.       (setvar "osmode" 0)
  8.       (setq p2 (polar p1 0 1000))
  9.       (command "line" p1 p2 "")
  10.       (setq s1 (entlast)
  11.             dr (* (/ jd 180.) pi)
  12.             p3 (polar p1 (- dr) 1000)
  13.             p4 (polar p1 (- dr) 1200)
  14.             p5 (polar p1 (*(- dr)0.5) 600)
  15.       )
  16.       (command "line" p1 p3 "")
  17.       (setq s2 (entlast))
  18.       (command "chprop" s2 "" "c" 1 "")
  19.       (command "text" "j" "mc" p4 300 0 "N")
  20.       (command "dimangular" (list s2 p3)(list s1 p2)  p5)
  21.     )
  22.   )
  23.   (princ)
  24. )
 楼主| 发表于 2024-9-8 21:18:09 | 显示全部楼层
感谢版主回复~
请问no function definition: UREAL是怎么回事?
 楼主| 发表于 2024-9-10 09:09:18 | 显示全部楼层
原来修改了回复不会有帖子的提示……
再请问一下版主,因为我想实现旋转功能,角度只是相对于直线的夹角,可以实现吗?
另外可否解释一下dr (* (/ jd 180.) pi)是什么意思?特别是180后面的那个点的作用,谢谢~
 楼主| 发表于 2024-9-17 14:56:21 | 显示全部楼层
虽然还是没完全看懂版主的这段代码,但提供了解决的思路,结合其他的代码已经搞定了我的需求,再次感谢~
GMT+8, 2026-1-23 02:25 , Processed in 0.166520 second(s), 29 queries , Gzip On.
