查看: 1272|回复: 0
Sweeping an AutoCAD solid dynamically using Kinect
发表于 2011-5-31 13:38:19 | 显示全部楼层 |阅读模式
作者:kean
原文地址:http://through-the-interface.typepad.com/through_the_interface/2011/05/sweeping-an-autocad-solid-dynamically-using-kinect.html
After focusing on a manual process for sweeping a solid inside AutoCAD in this previous post, it seemed to make sense to attempt to automate more of that process. In the code in this post, we take a standard circular profile – of a user-specified radius – and sweep it along the path defined by the user’s hand movements. Back in the original Kinect integration example we created a 3D polyline path linking every position of the user’s hand detected by Kinect. This makes a very jittery path for our purposes, so we’re going to define a spline along fit points that are at least 100 drawing units apart.
The jig will continually recreate the solid by sweeping the circular profile along the spline path, but clearly as the path grows, the sweep operation will get longer (and the interactivity will drop pretty drastically). This is quite clear from the results in the video:
http://www.youtube.com/embed/scA8abv5gns
It should be possible to increase the responsiveness by sweeping the solid in sections (for instance) and then creating the final contiguous solid at the end, but that kind of performance optimisation has been left out of the current implementation.
The implementation watches for exceptions during the sweep operation, swapping the spline path in to replace the solid if it wasn’t possible to create it.
Here’s the C# code:
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.EditorInput;
using Autodesk.AutoCAD.Geometry;
using Autodesk.AutoCAD.Runtime;
using AcGi = Autodesk.AutoCAD.GraphicsInterface;
using System.Runtime.InteropServices;
using System.Collections.Generic;
using System.Windows.Media;
using System.Diagnostics;
using System.Reflection;
using System.Linq;
using System.IO;
using System;
using NKinect;
namespace KinectIntegration
  public class KinectSweepJig : DrawJig
    [DllImport("acad.exe", CharSet = CharSet.Auto,
      CallingConvention = CallingConvention.Cdecl,
      EntryPoint = "?acedPostCommand@@YAHPB_W@Z"
    extern static private int acedPostCommand(string strExpr);
    // Draw our transient spline in red
    const short transPathColor = 1;
    // Our transient solids (cursor sphere & tube) are yellow
    const short transSolColor = 2;
    // Our final solids will be green
    const short finalSolColor = 3;
    // A transaction and database to add solids
    private Transaction _tr;
    private Document _doc;
    // We need our nKinect sensor
    private Sensor _kinect = null;
    // A list of points captured by the sensor
    // (for eventual export)
    private List<ColorVector3> _vecs;
    // A list of points to be displayed
    // (we use this for the jig)
    private Point3dCollection _points;
    // A list of vertices to draw our spline between
    private Point3dCollection _vertices;
    // The most recent vertex being captured/drawn
    private Point3d _curPt;
    // Our cursor sphere
    private Entity _cursor;
    // Entities to create our solid
    private Entity _profile;   // A profile circle
    private Spline _path;      // A spline path
    private Solid3d _tube;     // The solid itself
    private bool _sweepBroken; // Can the sweep continue?
    // The sweep options for creating the solid
    private SweepOptions _sweepOpts;
    // The radius of the profile circle to create
    private double _profRad;
    // An offset value we use to move the mouse back
    // and forth by one screen unit
    private int _offset;
    // Flags to indicate Kinect gesture modes
    private bool _firstCall;   // First skeleton callback
    private bool _calibrating; // Calibrating - show red
    private int _calibTicks;   // Number of frames to show red
    private bool _drawing;     // Drawing mode active
    private bool _finished;    // Finished - want to exit
    public bool Finished
      get { return _finished; }
    public KinectSweepJig(
      Document doc, Transaction tr, double profRad
      // Initialise the various members
      _doc = doc;
      _tr = tr;
      _points = new Point3dCollection();
      _vertices = new Point3dCollection();
      _cursor = null;
      _offset = 1;
      _calibrating = false;
      _calibTicks = 3;
      _drawing = false;
      _finished = false;
      _profile = null;
      _sweepOpts = null;
      _path = null;
      _tube = null;
      _profRad = profRad;
      _firstCall = true;
      _sweepBroken = false;
      // Create our sensor object - the constructor takes
      // three callbacks to receive various data:
      // - skeleton movement
      // - rgb data
      // - depth data
      _kinect =
        new Sensor(
          s =>
            if (_firstCall)
              _calibrating = true;
              _firstCall = false;
            if (!_calibrating && !_finished)
              _drawing = (s.LeftHand.Y < s.LeftHip.Y);
              // Get the current position of the hands
              Point3d right =
                new Point3d(
                  s.RightHand.X,
                  s.RightHand.Y,
                  s.RightHand.Z
              Point3d left =
                new Point3d(
                  s.LeftHand.X,
                  s.LeftHand.Y,
                  s.LeftHand.Z
              if (left.DistanceTo(right) < 50.0)
                _drawing = false;
                _finished = true;
              if (_drawing)
                // If we have at least one prior vertex...
                if (_vertices.Count > 0)
                  Point3d lastVert =
                    _vertices[_vertices.Count - 1];
                  if (lastVert.DistanceTo(right) > 100)
                    // Add the new vertex to our list
                    _vertices.Add(right);
                else
                  // Add the first vertex to our list
          r =>
          d =>
    public void StartSensor()
      if (_kinect != null)
        _kinect.Start();
    public void StopSensor()
        _kinect.Stop();
        _kinect.Dispose();
        _kinect = null;
    public void Cleanup()
      if (_path != null)
        _path.Dispose();
        _path = null;
      if (_profile != null)
        _profile.Dispose();
        _profile = null;
      if (_tube != null)
        _tube.Dispose();
        _tube = null;
      _sweepOpts = null;
      _vertices.Clear();
    protected override SamplerStatus Sampler(JigPrompts prompts)
      // Se don't really need a point, but we do need some
      // user input event to allow us to loop, processing
      // for the Kinect input
      PromptPointResult ppr =
        prompts.AcquirePoint("\nClick to capture: ");
      if (ppr.Status == PromptStatus.OK)
        if (_finished)
          acedPostCommand("CANCELCMD");
          return SamplerStatus.Cancel;
        if (!_drawing && (_path != null ||_tube != null))
          AddSolidOrPath();
        // Generate a point cloud via nKinect
        try
          List<ColorVector3> vecList =
            _kinect.GeneratePointCloud();
          // Apply a bounding box filter, if one is defined
          if (KinectCommands.Extents.HasValue)
            Extents3d ext = KinectCommands.Extents.Value;
            // Use LINQ to get the points within the
            // bounding box
            var vecSet =
              from ColorVector3 vec in vecList
              where
                vec.X > ext.MinPoint.X &&
                vec.X < ext.MaxPoint.X &&
                vec.Y > ext.MinPoint.Y &&
                vec.Y < ext.MaxPoint.Y &&
                vec.Z > ext.MinPoint.Z &&
                vec.Z < ext.MaxPoint.Z
              select vec;
            // Convert our IEnumerable<> into a List<>
            _vecs = vecSet.ToList<ColorVector3>();
          else
            _vecs = vecList;
          // Extract the points for display in the jig
          // (note we only take 1 in 5)
          _points.Clear();
          for (int i = 0; i < _vecs.Count; i += 10)
            ColorVector3 vec = _vecs[i];
            _points.Add(
              new Point3d(vec.X, vec.Y, vec.Z)
          // Let's move the mouse slightly to avoid having
          // to do it manually to keep the input coming
          System.Drawing.Point pt =
            System.Windows.Forms.Cursor.Position;
          System.Windows.Forms.Cursor.Position =
            new System.Drawing.Point(
              pt.X, pt.Y + _offset
          _offset = -_offset;
        catch {}
        return SamplerStatus.OK;
    protected override bool WorldDraw(AcGi.WorldDraw draw)
      short origCol = draw.SubEntityTraits.Color;
      if (_calibrating)
        draw.SubEntityTraits.Color = transPathColor;
        if (--_calibTicks == 0)
      // This simply draws our points
      draw.Geometry.Polypoint(_points, null, null);
      if (_drawing)
        try
          // Let's start by creating our spline path
          if ((_path == null && _vertices.Count > 1) ||
              (_path != null &&
                _vertices.Count > _path.NumFitPoints))
            if (_path != null)
              _path.Dispose();
            _path = new Spline(_vertices, 0, 0.0);
            // And our sweep profile, if we don't have one
              _profile.Dispose();
            _profile =
              new Circle(
                _vertices[0],
                _vertices[1] - _vertices[0],
                _profRad
            // And our sweep options, if we don't have one
            if (_sweepOpts == null)
              SweepOptionsBuilder sob =
                new SweepOptionsBuilder();
              // Align the entity to sweep to the path
              sob.Align =
                SweepOptionsAlignOption.AlignSweepEntityToPath;
              // The base point is the start of the path
              sob.BasePoint = _path.StartPoint;
              // The profile will rotate to follow the path
              sob.Bank = true;
              _sweepOpts = sob.ToSweepOptions();
            // Finally create a blank solid, if it's null
            if (_tube == null)
              _tube = new Solid3d();
            // And sweep our profile along our path
            _tube.CreateSweptSolid(_profile, _path, _sweepOpts);
        catch (Autodesk.AutoCAD.Runtime.Exception ex)
          _sweepBroken = true;
          _tube.Dispose();
          _tube = null;
          _doc.Editor.WriteMessage(
            "\nException: {0}", ex.Message
        // Draw our path, if we have one
        if (_path != null)
          _path.WorldDraw(draw);
        // And our solid
        if (_tube != null)
          draw.SubEntityTraits.Color = transSolColor;
          _tube.WorldDraw(draw);
          Point3d lastPt = _vertices[_vertices.Count - 1];
          if (_cursor == null)
            // Create a cursor sphere
            _cursor = new Solid3d();
            ((Solid3d)_cursor).CreateSphere(_profRad);
            _curPt = Point3d.Origin;
          _cursor.TransformBy(
            Matrix3d.Displacement(lastPt - _curPt)
          _curPt = lastPt;
          // Draw the cursor
            (_sweepBroken ? transPathColor : transSolColor);
          _cursor.WorldDraw(draw);
      draw.SubEntityTraits.Color = origCol;
      return true;
    public void AddSolidOrPath()
      if (_tube != null || _path != null)
        // Create a true database-resident 3D solid
        // (and let it be green)
        Entity ent;
        if (_tube == null)
          ent = _path;
          _path = null;
        else
          ent = _tube;
          _tube = null;
        BlockTableRecord btr =
          (BlockTableRecord)_tr.GetObject(
            _doc.Database.CurrentSpaceId,
            OpenMode.ForWrite
        ent.ColorIndex = finalSolColor;
        btr.AppendEntity(ent);
        _tr.AddNewlyCreatedDBObject(ent, true);
      Cleanup();
      _vertices.Clear();
    public void ExportPointCloud(string filename)
      if (_vecs.Count > 0)
        using (StreamWriter sw = new StreamWriter(filename))
          // For each pixel, write a line to the text file:
          // X, Y, Z, R, G, B
          foreach (ColorVector3 pt in _vecs)
            sw.WriteLine(
              "{0}, {1}, {2}, {3}, {4}, {5}",
              pt.X, pt.Y, pt.Z, pt.R, pt.G, pt.B
  public class SweepCommands
    [CommandMethod("ADNPLUGINS", "KINEXT", CommandFlags.Modal)]
    public void ImportFromKinect()
      Document doc =
        Autodesk.AutoCAD.ApplicationServices.
          Application.DocumentManager.MdiActiveDocument;
      Editor ed = doc.Editor;
      Transaction tr =
        doc.TransactionManager.StartTransaction();
      PromptDoubleOptions pdo =
        new PromptDoubleOptions("\nEnter profile radius");
      pdo.AllowZero = false;
      pdo.AllowNegative = false;
      pdo.AllowNone = false;
      pdo.DefaultValue = 40;
      pdo.UseDefaultValue = true;
      PromptDoubleResult pdr = ed.GetDouble(pdo);
      if (pdr.Status != PromptStatus.OK)
        return;
      KinectSweepJig kj =
        new KinectSweepJig(doc, tr, pdr.Value);
      kj.StartSensor();
      PromptResult pr = ed.Drag(kj);
      kj.StopSensor();
      if (pr.Status != PromptStatus.OK && !kj.Finished)
        kj.Cleanup();
        tr.Dispose();
        return;
      kj.AddSolidOrPath();
      tr.Commit();
      // Manually dispose to avoid scoping issues with
      // other variables
      tr.Dispose();
      // We'll store most local files in the temp folder.
      // We get a temp filename, delete the file and
      // use the name for our folder
      string localPath = Path.GetTempFileName();
      File.Delete(localPath);
      Directory.CreateDirectory(localPath);
      localPath += "\\";
      // Paths for our temporary files
      string txtPath = localPath + "points.txt";
      string lasPath = localPath + "points.las";
      // Our PCG file will be stored under My Documents
      string outputPath =
        Environment.GetFolderPath(
          Environment.SpecialFolder.MyDocuments
        ) + "\\Kinect Point Clouds\\";
      if (!Directory.Exists(outputPath))
        Directory.CreateDirectory(outputPath);
      // We'll use the title as a base filename for the PCG,
      // but will use an incremented integer to get an unused
      // filename
      int cnt = 0;
      string pcgPath;
      do
        pcgPath =
          outputPath + "Kinect" +
          (cnt == 0 ? "" : cnt.ToString()) + ".pcg";
        cnt++;
      while (File.Exists(pcgPath));
      // The path to the txt2las tool will be the same as the
      // executing assembly (our DLL)
      string exePath =
        Path.GetDirectoryName(
          Assembly.GetExecutingAssembly().Location
      if (!File.Exists(exePath + "txt2las.exe"))
        ed.WriteMessage(
          "\nCould not find the txt2las tool: please make sure " +
          "it is in the same folder as the application DLL."
        return;
      // Export our point cloud from the jig
      ed.WriteMessage(
        "\nSaving TXT file of the captured points.\n"
      kj.ExportPointCloud(txtPath);
      // Use the txt2las utility to create a .LAS
      // file from our text file
      ed.WriteMessage(
        "\nCreating a LAS from the TXT file.\n"
      ProcessStartInfo psi =
        new ProcessStartInfo(
          exePath + "txt2las",
          "-i \"" + txtPath +
          "\" -o \"" + lasPath +
          "\" -parse xyzRGB"
      psi.CreateNoWindow = false;
      psi.WindowStyle = ProcessWindowStyle.Hidden;
      // Wait up to 20 seconds for the process to exit
      try
        using (Process p = Process.Start(psi))
          p.WaitForExit();
      catch
      // If there's a problem, we return
      if (!File.Exists(lasPath))
        ed.WriteMessage(
          "\nError creating LAS file."
        return;
      File.Delete(txtPath);
      ed.WriteMessage(
        "Indexing the LAS and attaching the PCG.\n"
      // Index the .LAS file, creating a .PCG
      string lasLisp = lasPath.Replace('\\', '/'),
              pcgLisp = pcgPath.Replace('\\', '/');
      doc.SendStringToExecute(
        "(command \"_.POINTCLOUDINDEX\" \"" +
          lasLisp + "\" \"" +
          pcgLisp + "\")(princ) ",
        false, false, false
      // Attach the .PCG file
        "_.WAITFORFILE \"" +
        pcgLisp + "\" \"" +
        lasLisp + "\" " +
        "(command \"_.-POINTCLOUDATTACH\" \"" +
        pcgLisp +
        "\" \"0,0\" \"1\" \"0\")(princ) ",
        false, false, false
        "_.-VISUALSTYLES _C _Conceptual ",
        false, false, false
    // Return whether a file is accessible
    private bool IsFileAccessible(string filename)
      // If the file can be opened for exclusive access it means
      // the file is accesible
      try
        FileStream fs =
          File.Open(
            filename, FileMode.Open,
            FileAccess.Read, FileShare.None
        using (fs)
          return true;
      catch (IOException)
        return false;
    // A command which waits for a particular PCG file to exist
    [CommandMethod(
      "ADNPLUGINS", "WAITFORFILE", CommandFlags.NoHistory
    public void WaitForFileToExist()
      Document doc =
      HostApplicationServices ha =
        HostApplicationServices.Current;
      PromptResult pr = ed.GetString("Enter path to PCG: ");
      if (pr.Status != PromptStatus.OK)
        return;
      string pcgPath = pr.StringResult.Replace('/', '\\');
      pr = ed.GetString("Enter path to LAS: ");
        return;
      string lasPath = pr.StringResult.Replace('/', '\\');
      ed.WriteMessage(
        "\nWaiting for PCG creation to complete...\n"
      // Check the write time for the PCG file...
      // if it hasn't been written to for at least half a second,
      // then we try to use a file lock to see whether the file
      // is accessible or not
      const int ticks = 50;
      TimeSpan diff;
      bool cancelled = false;
      // First loop is to see when writing has stopped
      // (better than always throwing exceptions)
      while (true)
        if (File.Exists(pcgPath))
          DateTime dt = File.GetLastWriteTime(pcgPath);
          diff = DateTime.Now - dt;
          if (diff.Ticks > ticks)
            break;
        System.Windows.Forms.Application.DoEvents();
      // Second loop will wait until file is finally accessible
      // (by calling a function that requests an exclusive lock)
      if (!cancelled)
        int inacc = 0;
        while (true)
          if (IsFileAccessible(pcgPath))
            break;
          else
            inacc++;
        ed.WriteMessage("\nFile inaccessible {0} times.", inacc);
        try
          CleanupTmpFiles(lasPath);
        catch
    internal void CleanupTmpFiles(string txtPath)
      if (File.Exists(txtPath))
      Directory.Delete(
        Path.GetDirectoryName(txtPath)
I’ve made a start on a navigation-focused implementation, but I have to make some changes: right now it jigs a point cloud – just as the previous implementations have done – but as we’re going to be adjusting the view the points would need careful transformation to be at the right place on the screen. So some kind of glyph or avatar that represents the user’s gestures or direction of movement would be simpler (and ultimately less confusing from a visual perspective, I expect).
GMT+8, 2025-11-25 10:18 , Processed in 0.240116 second(s), 31 queries , Gzip On.
