查看: 1483|回复: 0
Minesweeper in AutoCAD using .NET
发表于 2011-7-7 17:21:39 | 显示全部楼层 |阅读模式
作者:kean
原文地址:http://through-the-interface.typepad.com/through_the_interface/2011/07/minesweeper-in-autocad-using-net.html
Today’s post contains some fun code contributed by Stephen Preston which re-creates  the Minesweeper video game inside AutoCAD. Stephen tells me it needs a bit of polishing, but the game is certainly playable. I’ve reformatted some of Stephen’s code to fit this blog.
The implementation comprises two main files, which you can name as you wish. I’ve used the VS 2010 convention for line-breaks (which means you don’t need an underscore). If you’re using older versions of Visual Sudio or Visual Basic Express you may need to concatenate lines or insert underscores at the end of them.
Here’s the main VB.NET file implementation the commands:
Imports Autodesk.AutoCAD.Runtime
Imports Autodesk.AutoCAD.ApplicationServices
Imports Autodesk.AutoCAD.DatabaseServices
Imports Autodesk.AutoCAD.Geometry
Imports Autodesk.AutoCAD.EditorInput
Imports System
' This line is not mandatory, but improves loading performance
<Assembly: CommandClass(GetType(Minesweeper.MyCommands))>
Namespace Minesweeper
  Public Class MyCommands
    'This is the main Minesweeper command.
    'It createas a new document, and invokes the worker
    'command(RUNMINESWEEPER) in the new document.
    <CommandMethod(
      "SGP_Minesweeper", "MINESWEEPER", "MINESWEEPER",
      CommandFlags.Session
    Public Shared Sub Minesweeper()
      Dim doc As Document = Application.DocumentManager.Add("")
      Application.DocumentManager.MdiActiveDocument = doc
      doc.SendStringToExecute("RUNMINESWEEPER ", True, False, False)
    End Sub
    'This is the worker command invoked usign SendStringToExecute
    'It starts the game running in the new doc created by the
    ' MINESWEEPER command.
    <CommandMethod(
      "SGP_Minesweeper", "RUNMINESWEEPER", CommandFlags.Modal
    Public Shared Sub RunMinesweeper()
      Try
        'Make sure new document has the text style we need
        DefineTextStyle()
        'Instantiate the game controller class and set game running
        Dim cls As New AcadMinesweeper
        cls.DoIt()
      Catch ex As Autodesk.AutoCAD.Runtime.Exception
        Application.DocumentManager.MdiActiveDocument.Editor.
          WriteMessage(vbCrLf &
            "Sorry - An error occurred. Game aborted." & vbCrLf)
      End Try
    End Sub
    'Adds a new text style to the drawing (if not already there)
    Private Shared Sub DefineTextStyle()
      Dim db As Database = HostApplicationServices.WorkingDatabase
      Dim tm As Autodesk.AutoCAD.DatabaseServices.TransactionManager
      tm = db.TransactionManager
      Dim myT As Transaction = tm.StartTransaction()
      Try
        Dim st As TextStyleTable =
          CType(
            tm.GetObject(
              db.TextStyleTableId, OpenMode.ForWrite, False),
            TextStyleTable)
        If Not st.Has("MinesweeperStyle") Then
          Dim str As TextStyleTableRecord =
            New TextStyleTableRecord()
          str.Name = "MinesweeperStyle"
          st.Add(str)
          str.FileName = "txt.shx"
          str.TextSize = 1.0
          str.IsShapeFile = True
          tm.AddNewlyCreatedDBObject(str, True)
        End If
        myT.Commit()
      Finally
        myT.Dispose()
      End Try
    End Sub
  End Class
  'This class governs our logic in AutoCAD.
  'It uses the MinesweeperMgr class to hold/query/edit the game data.
  '(Really needs a little more work to push more of the game logic
  'to Minesweeper Mgr).
  Public Class AcadMinesweeper
    'Links ObjectId of MText representing a mine cell to the row and
    ' column of the mine cell it represents
    Private Structure MineElement
      Public Id As ObjectId
      Public Row As Integer
      Public Col As Integer
    End Structure
    Private mMineMgr As New MinesweeperMgr 'Our manager class
    Private mMinefield() As MineElement ' Array of ObjectIds relating
                                        ' MText to their row and col
    'Main game controller function
    Public Sub DoIt()
      Dim ed As Editor =
      'Prompt user for values to setup minefield
      If Not PromptSetup() Then
        ed.WriteMessage(
          vbCrLf & "You cancelled setup - aborting command" & vbCrLf)
        Exit Sub
      End If
      'Tell manager class to setup its grid
      'I'm use this MinesweeperMgr class to keep the game data
      '(in MinesweeperMgr) separated from the UI logic
      '(in AcadMinesweeper), so I can re-use it in other apps
      mMineMgr.InitMinefield()
      'Transfer calculated grid from the manager to the current
      'document/drawing
      If Not SetupGrid() Then
        ed.WriteMessage(
          vbCrLf & "There was a problem setting up the minefield" &
          " - aborting command" & vbCrLf)
        Exit Sub
      End If
      Dim startTime As DateTime = DateTime.Now
      ' The game loop
      While PromptMineAction()
      End While
      ' Game over - tell user how long the game lasted.
      Dim timeInterval As TimeSpan = DateTime.Now - startTime
      ed.WriteMessage(
        vbCrLf & "Time taken = " & timeInterval.TotalSeconds &
        " seconds" & vbCrLf)
    End Sub
    ' Prompt user to perform an action - clear/mark/unmark a cell
    ' in the minefield
    Private Function PromptMineAction() As Boolean
      'bMarking governs behavior depending on whether we're
      'clearing mines or marking them
      Static bMarking As Integer
      Dim strMsg As String = ""
      Dim strKeyword As String = ""
      'Setup prompts and keywords according to bMarking
      Select Case bMarking
        Case False
          strMsg = "Select a cell to uncover:"
          strKeyword = "Mark"
        Case True
          strMsg = "Select a cell to mark/unmark:"
          strKeyword = "Uncover"
      End Select
      'Prompt user to perform action
      Dim ed As Editor =
      Dim opts As New PromptEntityOptions(vbCrLf & strMsg)
      opts.Keywords.Add(strKeyword)
      opts.AppendKeywordsToMessage = True
      opts.AllowNone = True
      Dim res As PromptEntityResult = ed.GetEntity(opts)
      'If user cancelled the command prompt then we end the game
      '(returning false ends the game loop).
      If res.Status = PromptStatus.Cancel Then
        ed.WriteMessage(
          vbCrLf & "You cancelled the game. Byeee!" & vbCrLf)
        Return False
      End If
      ' Don't let user escape command by pressing enter -
      ' just loop around again
      If res.Status = PromptStatus.None Then
        Return True
      End If
      'If user entered keyword, then we're toggling between
      ' mine clearing and mine marking
      If res.Status = PromptStatus.Keyword Then
        Select Case res.StringResult
          Case "Mark"
            bMarking = True
          Case Else
            bMarking = False
        End Select
        Return True
        'If user selected an entity (which must be MText
        ' because this is a new document, and that's all
        ' we added to it), then we use the ObjectId to
        ' retrieve its row and column in the grid.
      ElseIf res.Status = PromptStatus.OK Then
        Dim elem As MineElement = FindInMinefield(res.ObjectId)
        'This next if statement should never be used.
        If elem.Id = ObjectId.Null Then
          ed.WriteMessage(
            vbCrLf & "You didn't select a cell in the minefield." &
            vbCrLf)
          Return True
        End If
        'Check they didn't pick on a cell they already uncovered.
        If mMineMgr.CellIsUnCovered(elem.Row, elem.Col) Then
          ed.WriteMessage(
            vbCrLf & "This cell is already uncovered. " &
            "Pick another." & vbCrLf)
          Return True
        End If
        'If we got to here, then MText was picked, it is in the
        'grid, and it isn't uncovered yet.
        'If we're marking cells ...
        If bMarking Then
          'MarkCell toggles mark status
          Dim oldCellVal As MineCell =
            mMineMgr.MarkCell(elem.Row, elem.Col)
          If oldCellVal.Status = CellStatus.Covered Then
            'If cell was marked then we unmark it
            If oldCellVal.Status = CellStatus.Marked Then
              SetText(elem.Id, "X")
            Else 'If cell wasn't marked, we mark it.
              SetText(elem.Id, "M")
            End If
            'Go to next loop iteration
            Return True
          End If
        Else 'If we're clearing cells
            mMineMgr.UncoverCell(elem.Row, elem.Col)
          If oldCellVal.isBomb Then
            'We hit a bomb -  game over
            SetText(elem.Id, "*")
            ed.WriteMessage(
              vbCrLf & "You hit a mine. Game Over!." & vbCrLf)
            Return False
          Else
            ' It wasn't a bomb
            SetText(elem.Id, oldCellVal.Value.ToString)
            ' If we've cleared all cells except the bombs,
            ' then we won - game over.
            If mMineMgr.AllEmptyCellsUncovered Then
              ed.WriteMessage(
                vbCrLf & "Congratulations. " &
                "You cleared all the mines." & vbCrLf)
              Return False
            Else 'Carry on game
              Return True
            End If
          End If
        End If
      End If
    End Function
    'Set the text for an MText entity with the provided ObjectId
    Private Sub SetText(
      ByVal objId As ObjectId, ByVal strText As String)
        Application.DocumentManager.MdiActiveDocument.Database
      Using tr As Transaction =
        db.TransactionManager.StartTransaction
        Dim txt As MText = tr.GetObject(objId, OpenMode.ForWrite)
        txt.Contents = strText
        tr.Commit()
      End Using
    End Sub
    'Retrieve text from the MText entity with the provided ObjectId
    Private Function GetText(ByVal objId As ObjectId)
      Dim strText As String
        Dim txt As MText = tr.GetObject(objId, OpenMode.ForRead)
        strText = txt.Contents
        tr.Commit()
      End Using
      Return strText
    End Function
    ' Find MineElement with provided ObjectId in our array of all
    ' mine cells. This is how we asociate row and column value
    ' with an MText entity
    Private Function FindInMinefield(
      ByVal objId As ObjectId) As MineElement
      For Each elem As MineElement In mMinefield
        If elem.Id = objId Then
          Return elem
        End If
      Next
      'If we didn't find it, we return a blank - calling function
      'should query for null ObjectId
      Return New MineElement
    End Function
    'Create all the MText entities in our grid and zoom to fill
    'screen
    Private Function SetupGrid() As Boolean
      Dim bFlag As Boolean = False
      Try
          Dim tst As TextStyleTable =
            tr.GetObject(db.TextStyleTableId, OpenMode.ForRead)
          Dim textStyleId As ObjectId = tst.Item("MinesweeperStyle")
          Dim btr As BlockTableRecord =
            CType(
              tr.GetObject(
                SymbolUtilityServices.GetBlockModelSpaceId(db),
                OpenMode.ForWrite),
              BlockTableRecord)
          Dim rows As Integer = mMineMgr.MinefieldRows
          Dim cols As Integer = mMineMgr.MinefieldColumns
          ReDim mMinefield(rows * cols - 1)
          For i As Integer = 0 To rows - 1
            For j = 0 To cols - 1
              Using txt As MText = New MText
                txt.SetDatabaseDefaults()
                txt.TextStyleId = textStyleId
                txt.Location = New Point3d(i, j, 0)
                txt.Width = 1.0
                txt.Height = 1.0
                txt.TextHeight = 0.8
                txt.Attachment = AttachmentPoint.MiddleCenter
                mMinefield(i * rows + j).Id = btr.AppendEntity(txt)
                mMinefield(i * rows + j).Row = i
                mMinefield(i * rows + j).Col = j
                txt.Contents = "X"
                tr.AddNewlyCreatedDBObject(txt, True)
              End Using
            Next
          Next
          tr.Commit()
          ModelZoomExtents()
        End Using
        bFlag = True
        bFlag = False
      End Try
      ' If bFlag is true, then all mtexts were added to
      'DB without problem
      Return bFlag
    End Function
    'Prompt user for grid size and number of mines, and pass those
    'to the MinesweeperMgr to initialize itself
    Private Function PromptSetup() As Boolean
      Dim ed As Editor =
      Dim opts1 As New PromptIntegerOptions(
        "Enter Minefield width:")
      opts1.LowerLimit = 1
      opts1.UpperLimit = 100
      opts1.DefaultValue = 10
      Dim res1 As PromptIntegerResult = ed.GetInteger(opts1)
      If res1.Status <> PromptStatus.OK Then
        Return False
      End If
      mMineMgr.MinefieldRows = res1.Value
      opts1.Message = "Enter minefield height:"
      res1 = ed.GetInteger(opts1)
        Return False
      End If
      mMineMgr.MinefieldColumns = res1.Value
      opts1.Message = "Enter number of mines:"
      opts1.UpperLimit =
        mMineMgr.MinefieldRows * mMineMgr.MinefieldColumns
        mMineMgr.MinefieldRows * mMineMgr.MinefieldColumns / 6
        Return False
      End If
      mMineMgr.NumMines = res1.Value
      Return True
    End Function
    'The next two functions are helper functions to zoom to the grid.
    'Code copied from ADN DevNote
    Public Sub SetViewportToExtents(
      ByVal db As Database, ByVal vtr As ViewportTableRecord)
      'Let's update the database extents first
      'True gives the best fit but will take time
      db.UpdateExt(True)
      'Get the screen aspect ratio to calculate the height and width
      Dim scrRatio As Double = (vtr.Width / vtr.Height)
      'Prepare Matrix for DCS to WCS transformation
      Dim matWCS2DCS As Matrix3d =
        Matrix3d.PlaneToWorld(vtr.ViewDirection)
      'For DCS target point is the origin
      matWCS2DCS =
        Matrix3d.Displacement(vtr.Target - Point3d.Origin) *
        matWCS2DCS
      'WCS Xaxis is twisted by twist angle
      matWCS2DCS =
        Matrix3d.Rotation(
          -vtr.ViewTwist, vtr.ViewDirection, vtr.Target) *
        matWCS2DCS
      matWCS2DCS = matWCS2DCS.Inverse()
      'Tranform the extents to the DCS defined by the viewdir
      Dim extents As New Extents3d(db.Extmin, db.Extmax)
      extents.TransformBy(matWCS2DCS)
      'Width of the extents in current view
      Dim width As Double =
        (extents.MaxPoint.X - extents.MinPoint.X)
      'Height of the extents in current view
      Dim height As Double =
        (extents.MaxPoint.Y - extents.MinPoint.Y)
      'Get the view center point
      Dim center As New Point2d(
        (extents.MaxPoint.X + extents.MinPoint.X) * 0.5,
        (extents.MaxPoint.Y + extents.MinPoint.Y) * 0.5)
      'Check if the width 'fits' in current window
      'If not then get the new height as per the viewport's
      'aspect(ratio)
      If width > (height * scrRatio) Then
        height = width / scrRatio
      End If
      vtr.Height = height
      vtr.Width = height * scrRatio
      vtr.CenterPoint = center
      vtr.IconEnabled = False
    End Sub
    Public Sub ModelZoomExtents()
      Dim db As Database = doc.Database
      Dim ed As Editor = doc.Editor
      Using Tx As Transaction =
        db.TransactionManager.StartTransaction()
        ed.UpdateTiledViewportsInDatabase()
        Dim viewportTableRec As ViewportTableRecord =
          TryCast(
            Tx.GetObject(
              ed.ActiveViewportId, OpenMode.ForWrite),
        SetViewportToExtents(db, viewportTableRec)
        ed.UpdateTiledViewportsFromDatabase()
        Tx.Commit()
      End Using
    End Sub
  End Class
End Namespace
The second file implements – among other things – a MinesweeperMgr class that takes care of the main implementation of the game (aiding portability). This is a good technique to follow, where possible, as AutoCAD may not be the only (even if by some bizarre twist of fate it somehow ends up being the best ;-) environment for playing the Minesweeper game.
Here’s the MinesweeperMgr implementation file:
  Public Class MinesweeperException
    Inherits Exception
  End Class
  'Each cell can have one of these three statuses
  Public Enum CellStatus
    Covered
    Uncovered
    Marked
  End Enum
  Public Structure MineCell
    Public Sub New(
      ByVal status As CellStatus, ByVal val As Integer,
      ByVal bomb As Boolean, ByVal marked As Boolean)
      status = status
      isBomb = bomb
      Value = val
    End Sub
    Public Status As CellStatus 'Covered/Uncovered/Marked
    Public Value As Integer 'No of neighboring cells containing bombs
    Public isBomb As Boolean 'Is this cell a bomb?
  End Structure
  Public Class MinesweeperMgr
    Private mRows As Integer 'Rows in grid
    Private mCols As Integer 'Columns in grid
    Private mMineArray(,) As MineCell 'The grid
    Private mNumMines As Integer 'Number of mines hidden in grid
    Private mNumCellsUncovered 'Number of cells currently uncovered
    Public ReadOnly Property NumCellsUncovered() As Integer
      Get
        Return mNumCellsUncovered
      End Get
    End Property
    Private Function IncrementNumCellsUncovered() As Integer
      mNumCellsUncovered = mNumCellsUncovered + 1
    End Function
    Public Property MinefieldRows() As Integer
      Get
        Return mRows
      End Get
      Set(ByVal value As Integer)
        If value > 0 Then
          mRows = value
          If NumMines > mRows * MinefieldColumns Then
            NumMines = mRows * MinefieldColumns
          End If
        Else
          Throw New MinesweeperException
        End If
      End Set
    End Property
    Public Property MinefieldColumns() As Integer
      Get
        Return mCols
      End Get
        If value > 0 Then
          mCols = value
          If NumMines > MinefieldRows * mCols Then
            NumMines = MinefieldRows * mCols
          End If
        Else
        End If
      End Set
    End Property
    Public Property NumMines() As Integer
      Get
        Return mNumMines
      End Get
        If mNumMines <= (mCols * mRows) Then
          mNumMines = value
        Else
          mNumMines = mCols * mRows
        End If
      End Set
    End Property
    Public ReadOnly Property MineArray() As MineCell(,)
      Get
        Return mMineArray
      End Get
    End Property
    Public Function GetCell(
      ByVal row As Integer, ByVal col As Integer) As MineCell
      If row >= 0 And row < MinefieldRows And
         col >= 0 And col < MinefieldColumns Then
        Return mMineArray(row, col)
      Else
      End If
    End Function
    Public Function SetCell(
      ByVal row As Integer, ByVal col As Integer,
      ByVal value As MineCell) As Boolean
        mMineArray(row, col) = value
        Return True
      Else
      End If
    End Function
    Public Function UncoverCell(
      Dim curCellVal As MineCell = MineArray(row, col)
      If curCellVal.Status <> CellStatus.Uncovered Then
        MineArray(row, col).Status = CellStatus.Uncovered
      End If
      Return curCellVal
    End Function
    'Toggle cell between Covered and Marked Status.
    'Does nothing for Uncovered cells.
    'Returns previous MineCell values.
    Public Function MarkCell(
      If curCellVal.Status = CellStatus.Covered Then
        MineArray(row, col).Status = CellStatus.Marked
      ElseIf curCellVal.Status = CellStatus.Marked Then
        MineArray(row, col).Status = CellStatus.Covered
      End If
      Return curCellVal
    End Function
    'Returns true if cell is uncovered
    Public Function CellIsUnCovered(
      ByVal row As Integer, ByVal col As Integer) As Boolean
      If MineArray(row, col).Status = CellStatus.Uncovered Then
        Return True
      Else
        Return False
      End If
    End Function
    'Returns true if we've cleared all our non-mine cells
    Public Function AllEmptyCellsUncovered() As Boolean
      Return NumCellsUncovered =
         MinefieldColumns * MinefieldRows - NumMines
    End Function
    Public Sub InitMinefield()
      InitMinefield(MinefieldRows, MinefieldColumns, NumMines)
    End Sub
    Private Sub ResetNumCellsUncovered()
      mNumCellsUncovered = 0
    End Sub
    'Initialize grid, and put the mines in random locations
      ByVal rows As Integer, ByVal cols As Integer,
      ByVal num As Integer)
      If rows < 1 Or cols < 1 Or num < 1 Then
      End If
      MinefieldRows = rows
      MinefieldColumns = cols
      If num > rows * cols Then
        NumMines = rows * cols
      Else
        NumMines = num
      End If
      'Initialize grid (array) to represent minefield
      ReDim mMineArray(rows - 1, cols - 1)
      ' Add mines to grid (value of -1 means a mine is at
      ' that location)
      Randomize()
      Dim i As Integer = 0
      Do
        Dim rndRow As Integer = Rnd() * (MinefieldRows - 1)
        Dim rndCol As Integer = Rnd() * (MinefieldColumns - 1)
        If mMineArray(rndRow, rndCol).isBomb = False Then
          mMineArray(rndRow, rndCol).Value = -1
          mMineArray(rndRow, rndCol).isBomb = True
          mMineArray(rndRow, rndCol).Status = CellStatus.Covered
          i = i + 1
        End If
      Loop While i < num
      ' Now mines are added, we populate the rest of the grid
      ' with the numbers to indicate how many mines are in
      ' neighbouring(cells)
      For i = 0 To MinefieldRows - 1
        For j As Integer = 0 To MinefieldColumns - 1
          ' If this cell contains a mine then don't process it
          If mMineArray(i, j).isBomb = True Then
            Continue For
          End If
          Dim mineCounter As Integer = 0
          'Check grid cells around this one looking for mines ...
          ' i-1,j-1 | i,j-1 | i+1,j-1
          '   i-1,j |  i,j  | i+1,j
          ' i-1,j+1 | i,j+1 | i+1,j+1
          For k As Integer = -1 To 1
            For l As Integer = -1 To 1
              ' Skip over cells outside bounds of minefield
              If (i + k < 0) Or (i + k > MinefieldRows - 1) Or
                 (j + l < 0) Or (j + l > MinefieldColumns - 1) Then
                Continue For
              End If
              'Don't include cell (i,j)
              If k = 0 And l = 0 Then
                Continue For
              End If
              If mMineArray(i + k, j + l).isBomb = True Then
                mineCounter = mineCounter + 1
              End If
            Next
          Next
          mMineArray(i, j).Value = mineCounter
          mMineArray(i, j).Status = CellStatus.Covered
        Next
      Next
    End Sub
  End Class
End Namespace
When we run the MINESWEEPER command, it asks you for the size of the grid and the number of mines to hide inside it. It then displays a blank game:
As you uncover cells, you see the number of adjacent (straight and diagonal) cells containing mines. You continue to select cells until you hit a mine:
I’d show you a successfully completed game, but I’m clearly too far from my student days (and no longer have the requisite skills ;-).
Thanks for the “blast from the past” (boom boom… ouch – the puns are never-ending :-) and for the fun implementation, Stephen!
GMT+8, 2025-5-23 19:07 , Processed in 0.292860 second(s), 32 queries , Gzip On.
