- 积分
- 29105
- 明经币
- 个
- 注册时间
- 2003-8-26
- 在线时间
- 小时
- 威望
- 金钱
- 个
- 贡献
- 激情
早期我贴了一个假尺寸检查程序,总觉得缺点什么,今天完善了一下,希望能更好用一些。
;;; 名称: 《假尺寸检查》V2.0
;;; 功能:假尺寸(手动修改过的尺寸)数值显示红色
;;; 操作:运行jcc显示假尺寸,再次运行恢复不显示
;;; 连续不断运行闪烁。左键空拾取缩放,非
空拾取修改尺寸数值,右键退出。
;;; langjs
;;; 名称: 《假尺寸检查》v2.0
;;; 连续不断运行闪烁。支持修改假尺寸数值
;;; langjs
(defun c:jcc (/ #errjcc $orr ak bb bl col ctr dcl_pt dcl_re dclname ent er filen i jj k lb len1 len2 len3 n name name1 np1 np2 obj pt
px py scale screen ss ss0 ss1 ss3 stream tempname u wzgd wzh xsize xx ysize yy
(defun getcursorpos (pt / ctr ysize screen scale xsize lb xx yy) ; 点坐标近似转像素坐标供对话框定位
(setq ctr (getvar "VIEWCTR")
ysize (getvar "VIEWSIZE")
screen (getvar "SCREENSIZE")
scale (/ (car screen) (cadr screen))
xsize (* scale ysize)
lb (list (- (car ctr) (/ xsize 2)) (- (cadr ctr) (/ ysize 2)))
xx (- (car pt) (car lb))
yy (- (cadr pt) (cadr lb))
(list (fix (+ 50 (* (/ xx xsize) (car screen)))) (fix (+ 120 (- (cadr screen) (* (/ yy ysize) (cadr screen))))))
(defun #errjcc (s)
(if name1
(redraw name1 4)
(command ".UNDO" "E")
(c:jcc)
(setq *error* $orr)
(setq $orr *error*)
(setq *error* #errjcc)
(vl-load-com)
(setvar "cmdecho" 0)
(command ".UNDO" "BE")
(setq u t)
(while u
(if (progn
(setq ss (ssadd)
ss1 (ssadd)
(if (setq ss0 (ssget "X" '((0 . "DIMENSION"))))
(repeat (setq i (sslength ss0))
(setq ent (ssname ss0 (setq i (1- i))))
(if (= (vla-get-textcolor (vlax-ename->vla-object ent)) 1) ; 查找红色的假尺寸
(setq ss (ssadd ent ss))
(setq ss1 (ssadd ent ss1))
(if (> (sslength ss) 0)
(if (> (sslength ss1) 0)
(setq col (vla-get-textcolor (vlax-ename->vla-object (ssname ss1 0))))
(setq col (getint "\n 输入尺寸恢复颜色[1红,2黄,3绿,4青,5蓝,6洋红,7白]:<3>"))
(if (null col)
(setq col 3)
(> (sslength ss) 0)
(setq u nil)
(repeat (setq i (sslength ss))
(vlax-put-property (vlax-ename->vla-object (ssname ss (setq i (1- i)))) "textcolor" col) ; 颜色恢复
(if (setq ss (ssget "X" '((0 . "DIMENSION") (-4 . "<AND")
(-4 . "<NOT")
(1 . "")
(-4 . "NOT>")
(-4 . "<NOT")
(1 . "*<>*")
(-4 . "NOT>")
(-4 . "AND>")
(princ (strcat "\n 找到" (itoa (sslength ss)) "个假尺寸并显示红色。"))
(vlax-put-property (vlax-ename->vla-object (ssname ss (setq i (1- i)))) "textcolor" 1) ; 显示红色
(setq obj (vlax-ename->vla-object (ssname ss 0)))
(setq wzgd (vla-get-textheight obj)) ; 得到标注样式的文字高度
(setq bl (vla-get-scalefactor obj)) ; 得到标注的调整比例
(setq wzh (* wzgd bl)) ; 得到真正的文字高度
(setq er 888
jj 0
(while (or
(= er 7)
(= er 888)
(while (and
(setq name (entsel "点空白缩放,点尺寸查看:<右键退出>"))
(setq dcl_pt (getcursorpos (cadr name)))
(setq name (car name))
(= (cdr (assoc 0 (entget name))) "DIMENSION")
(command "delay" "50")
(setq ent (vlax-ename->vla-object name)
len3 (vla-get-textoverride ent)
len2 (vla-get-measurement ent)
(setq n 0
len1 ""
(repeat (strlen len3)
(setq k (substr len3 (setq n (+ 1 n))
1
ak (ascii k)
(if (/= ak 123 ak 125)
(setq len1 (strcat len1 k))
(setq dclname (cond
((setq tempname (vl-filename-mktemp "jcc.dcl")
filen (open tempname "w")
(foreach stream '("\n" "jcc:dialog { label = \"检查尺寸\" ;\n"
" :edit_box { label = \"假值\" ; key = \"e01\" ; width = 10 ; }\n"
" :edit_box { label = \"真值\" ; key = \"e02\" ; width = 10 ; }\n"
" :row {\n" " :button { label = \"修改\" ; key = \"e05\" ; }\n"
" :button { label = \"恢复\" ; key = \"e03\" ; is_default = true ; }\n"
" :button { label = \"取消\" ; key = \"e04\" ; is_cancel = true ; }\n"
" }\n" "}\n"
(princ stream filen)
(close filen)
tempname
(setq dcl_re (load_dialog dclname))
(if (not (new_dialog "jcc" dcl_re "" dcl_pt))
(exit)
(set_tile "e01" len1)
(set_tile "e02" (rtos len2))
(action_tile "e03" "(setq dcl_pt (done_dialog 1)) ")
(action_tile "e05" "(setq k (get_tile \"e01\" ) )(setq dcl_pt (done_dialog 2)) ")
(setq bb (start_dialog))
(if (= bb 2)
(vla-put-textoverride ent k)
(if (= bb 1)
(setq ss3 (ssget "x" '((0 . "dimension") (-4 . "<or")
(1 . "")
(1 . "*<>*")
(-4 . "or>")
(vla-put-textoverride ent "")
(if ss3
(setq col (vla-get-textcolor (vlax-ename->vla-object (ssname ss3 0))))
(if (null col)
(setq col 3)
(vlax-put-property ent "textcolor" col)
(unload_dialog dcl_re)
(vl-file-delete dclname)
(princ "\n ")
(setq er (getvar "errno"))
(if name1
(redraw name1 4)
(if (= er 7)
(if (>= jj (sslength ss))
(setq jj 0)
(alert (strcat "\n检查了" (itoa (sslength ss)) "个假尺寸,重新检查"))
(setq name1 (ssname ss jj))
(redraw name1 3)
(setq np1 (cdr (assoc 11 (entget name1))))
(setq px (car np1)
py (cadr np1)
np1 (list (- px (* wzh 40)) (- py (* wzh 20)) 0.0) ; 缩放窗口计算与字体高度关联
np2 (list (+ px (* wzh 40)) (+ py (* wzh 20)) 0.0)
(command "zoom" "W" np1 np2)
(setq jj (1+ jj))
(princ "\n ")
(setq u nil)
(alert "\n本图未找到假尺寸!")
(setq *error* $orr)
本帖被以下淘专辑推荐:
- · 应用类函数|主题: 200, 订阅: 27
- · 3D|主题: 8, 订阅: 0
