楼主: langjs
[源码] 动态轴测图工具2014.1月更新(源码)
 楼主| 发表于 2012-4-13 23:07:48 | 显示全部楼层
yansu 发表于 2012-4-13 08:10
提示没有字体,如何添加字体
不明白为什么会出现缺少字体的提示,程序新建标注式样和文字式样调用的是当前标注式样的字体,只要但前标注式样正常,按道理不会缺少字体.
下面是创建文字和标注式样的子程序,你看看问题出在什么地方?
;;; 程序初始化子程序(建立新的文字式样和标注式样)
(defun zct02 (/ ctrview dsy name pt0 pt1 pt2 pt3 pt4 pt5 sizeview snap thr tsy tsyent)
  (setq tsy (getvar "TEXTSTYLE"))      ; 取得当前文字式样名称
  (setq dsy (getvar "DIMSTYLE"))       ; 取得当前标注式样名称
  (setq tsyent (tblsearch "style" tsy)) ; 取得当前标注式样详细内容
  (setq thr (strcat (cdr (assoc 3 tsyent)) "," (cdr (assoc 4 tsyent)))) ; 取得当前标注式样shx字体和大字体内容
  (if (not (tblsearch "style" "+30"))  ; 文字样式"+30",无则创建
      (command "_style" "+30" thr 0 0.8 30 "N" "N") ; 将当前式样字体赋予新建文字式样
      (if (/= 0 (getvar "cmdactive"))
(command "N")
  (if (not (tblsearch "style" "-30"))  ; 文字样式"-30",无则创建
      (command "_style" "-30" thr 0 0.8 -30 "N" "N")
(command "N")
  (if (not (tblsearch "dimstyle" "+30")) ; 标注样式"+30",无则创建
    (progn          ; 新建箭头块
      (setq snap (getvar "osmode"))
      (setvar "osmode" 0)
      (setvar "cmdecho" 0)
      (setvar "cecolor" (itoa (getvar "DIMCLRD")))
      (setq sizeview (getvar "viewsize"))
      (setq ctrview (getvar "viewctr"))
      (setq pt0 '(0.0 0.0 0.0)
     pt1 '(-1.10647 0.184412 0.0)
     pt2 '(-0.89353 -0.184412 0.0)
     pt3 '(-1.10647 -0.184412 0.0)
     pt4 '(-0.89353 0.184412 0.0)
     pt5 '(-0.7 0.0 0.0)
      (command "zoom" "c" pt0 3)
      (entmake (list '(0 . "LWPOLYLINE") '(100 . "AcDbEntity") '(100 . "AcDbPolyline") (cons 90 4) (cons 10 pt0) (cons 10 pt1)
       (cons 10 pt2) (cons 10 pt0)
      (setq name (entlast))
      (command "bhatch" "p" "SOLID" pt5 "")
      (entdel name)
      (command "block" "箭头2" pt0 (entlast) "")
      (entmake (list '(0 . "LWPOLYLINE") '(100 . "AcDbEntity") '(100 . "AcDbPolyline") (cons 90 4) (cons 10 pt0) (cons 10 pt3)
       (cons 10 pt4) (cons 10 pt0)
      (entdel name)
      (command "block" "箭头1" pt0 (entlast) "")
      (command "zoom" "c" ctrview sizeview)
      (setvar "cecolor" "bylayer")
      (setvar "osmode" snap)        ; 新建箭头块结束
      (command "DIMTXSTY" "+30" "DIMBLK1" "箭头1" "DIMBLK2" "箭头1" "DIMSAH" 1 "DIMSTYLE" "S" "+30")
  (if (not (tblsearch "dimstyle" "-30")) ; 标注样式"-30",无则创建
      (command "DIMTXSTY" "-30" "DIMBLK1" "箭头2" "DIMBLK2" "箭头2" "DIMSAH" 1 "DIMSTYLE" "S" "-30")
  (setvar "TEXTSTYLE" tsy)        ; 恢复原来的文字式样
  (command "dimstyle" "r" dsy)        ; 恢复原来的标注式样
  (list tsy dsy)
发表于 2012-4-13 23:32:22 | 显示全部楼层
等老狼有时间优化下
已经更新了  发表于 2012-4-13 23:34
发表于 2012-4-13 23:40:25 | 显示全部楼层
1)想解决画图有点卡的问题。太卡了,画图始终不是办法。
2)命令行提示有点怪:
命令: zline
指定第一点:
指定下一点,或输入距离:空格默认<14.01>
1
12
122
指定下一点,或输入距离:空格默认<122>
2
22
222
指定下一点,或输入距离:空格默认<222>
3
33
333
指定下一点,或输入距离:空格默认<333>
4
44
444
指定下一点,或输入距离:空格默认<444>
5
55
555
指定下一点,或输入距离:空格默认<555>
发表于 2012-4-14 08:58:54 | 显示全部楼层
都是高手啊
发表于 2012-4-14 12:59:22 | 显示全部楼层
谢谢楼主提供源程序
发表于 2012-4-14 17:19:18 | 显示全部楼层
回复试一下
 楼主| 发表于 2012-4-15 21:47:50 | 显示全部楼层
2)命令行提示有点怪:
命令: zline
卡问题解决不了,命令行提示问题解决了
发表于 2012-4-15 23:52:38 | 显示全部楼层
非常的棒!谢谢分享
发表于 2012-4-16 09:07:01 | 显示全部楼层
发表于 2012-4-16 15:41:01 | 显示全部楼层
郞哥出源码了。谢谢!顶你啊!!
GMT+8, 2026-1-5 09:53 , Processed in 0.172920 second(s), 20 queries , Gzip On.
