查看: 885|回复: 0
Implementing drag & drop at a specific location in AutoCAD using .NET
发表于 2011-2-28 12:11:44 | 显示全部楼层 |阅读模式
原文地址:http://through-the-interface.typepad.com/through_the_interface/2011/02/implementing-drag-drop-at-a-specific-location-in-autocad-using-net.html
As a follow up to the last post, here’s the update that places the dropped content at the cursor location. I‘ve been busy in meetings for most of the week, so I haven’t yet had time to integrate the jig for sizing.
Thanks for Mike Schumacher for pointing me at Editor.PointToWorld() (I’m not sure how I managed to miss it – let’s blame it on the jetlag).
Here’s the updated C# code with the new/modified lines in red (and the complete, unnumbered source file here):
    1 using Autodesk.AutoCAD.ApplicationServices;
    2 using Autodesk.AutoCAD.DatabaseServices;
    3 using Autodesk.AutoCAD.EditorInput;
    4 using Autodesk.AutoCAD.Geometry;
    5 using Autodesk.AutoCAD.Runtime;
    6 using Autodesk.AutoCAD.Windows;
    7 using System.Runtime.InteropServices;
    8 using System.Windows.Forms;
    9 using System.Drawing;
   10 using System.IO;
   11 using System;
   12
   13 namespace DragAndDrop
   14 {
   15   public enum Msgs
   16   {
   17     WM_DRAWCLIPBOARD = 0x0308,
   18     WM_CHANGECBCHAIN = 0x030D
   19   }
   20
   21   public class ClipboardView : UserControl
   22   {
   23     [DllImport("user32.dll")]
   24     public static extern IntPtr SetClipboardViewer(
   25       IntPtr hWndNewViewer
   26     );
   27
   28     [DllImport("user32.dll", CharSet = CharSet.Auto)]
   29     public static extern IntPtr SendMessage(
   30       IntPtr hWnd, int Msg, IntPtr wParam, IntPtr lParam
   31     );
   32
   33     private IntPtr _nxtVwr;
   34     private PictureBox _img;
   35     private PaletteSet _ps;
   36
   37     public System.Drawing.Image Contents
   38     {
   39       get { return _img.Image; }
   40     }
   41
   42     public ClipboardView(PaletteSet ps)
   43     {
   44       _img = new PictureBox();
   45       _img.Anchor =
   46         (AnchorStyles)(AnchorStyles.Top |
   47                       AnchorStyles.Bottom |
   48                       AnchorStyles.Left |
   49                       AnchorStyles.Right);
   50       _img.Location = new Point(0, 0);
   51       _img.Size = this.Size;
   52       _img.SizeMode = PictureBoxSizeMode.StretchImage;
   53       Controls.Add(_img);
   54
   55       // Add our event handler to launch a new drag event
   56       // when someone clicks on the control
   57
   58       _img.MouseDown +=
   59         delegate(object sender, MouseEventArgs e)
   60         {
   61           // Simply initiate the drag & drop in AutoCAD,
   62           // specifying an instance of our custom "drop
   63           // target" class
   64
   65           Autodesk.AutoCAD.ApplicationServices.
   66           Application.DoDragDrop(
   67             _img, this.Contents, DragDropEffects.Copy,
   68             new MyDropTarget()
   69           );
   70         };
   71
   72       _nxtVwr = SetClipboardViewer(this.Handle);
   73       _ps = ps;
   74     }
   75
   76     private void ExtractImage()
   77     {
   78       IDataObject iData;
   79       try
   80       {
   81         iData = Clipboard.GetDataObject();
   82       }
   83       catch (System.Exception ex)
   84       {
   85         MessageBox.Show(ex.ToString());
   86         return;
   87       }
   88
   89       if (iData.GetDataPresent("Bitmap"))
   90       {
   91         object o = iData.GetData("Bitmap");
   92         Bitmap b = o as Bitmap;
   93         if (b != null)
   94         {
   95           _img.Image = b;
   96           if (_ps != null)
   97           {
   98             _ps.Size =
   99               new Size(b.Size.Width / 3, b.Size.Height / 3);
  100           }
  101         }
  102       }
  103     }
  104
  105     protected override void WndProc(ref Message m)
  106     {
  107       switch ((Msgs)m.Msg)
  108       {
  109         case Msgs.WM_DRAWCLIPBOARD:
  110           ExtractImage();
  111           SendMessage(_nxtVwr, m.Msg, m.WParam, m.LParam);
  112           break;
  113         case Msgs.WM_CHANGECBCHAIN:
  114           if (m.WParam == _nxtVwr)
  115             _nxtVwr = m.LParam;
  116           else
  117             SendMessage(_nxtVwr, m.Msg, m.WParam, m.LParam);
  118           break;
  119         default:
  120           base.WndProc(ref m);
  121           break;
  122       }
  123     }
  124   }
  125
  126   // Our custom drop target class
  127
  128   public class MyDropTarget : DropTarget
  129   {
  130     public override void OnDrop(DragEventArgs e)
  131     {
  132       Document doc =
  133         Autodesk.AutoCAD.ApplicationServices.Application.
  134         DocumentManager.MdiActiveDocument;
  135
  136       // If we have a valid bitmap, save it and send
  137       // our custom command (RINS)
  138
  139       if (e.Data.GetDataPresent("Bitmap"))
  140       {
  141         object o = e.Data.GetData("Bitmap");
  142         Bitmap b = o as Bitmap;
  143         if (b != null)
  144         {
  145           // We'll save the bitmap as a "temp" file
  146           // (as its unique - a better approach
  147           // would probably to create a unique file
  148           // in the same folder as the drawing, but
  149           // that's left to the reader)
  150
  151           string path = Path.GetTempFileName();
  152           b.Save(path);
  153
  154           // Call our command
  155
  156           string cmd =
  157             String.Format(
  158               "_RINS {0}\n{1},{2},0\n", path, e.X, e.Y
  159             );
  160           doc.SendStringToExecute(
  161             cmd, false, false, false
  162           );
  163         }
  164       }
  165     }
  166   }
  167
  168   public class Commands
  169   {
  170     private PaletteSet _ps = null;
  171     private ClipboardView _cv = null;
  172     static private Point3d _pt = Point3d.Origin;
  173
  174     [CommandMethod("DRAGDROP")]
  175     public void DragAndDropClipboardRaster()
  176     {
  177       if (_ps == null)
  178       {
  179         _ps = new PaletteSet(
  180           "DRAGDROP",
  181           new Guid("5C8FC28C-45ED-4796-BD40-28D235B6D7DA")
  182         );
  183
  184         if (_cv == null)
  185         {
  186           _cv = new ClipboardView(_ps);
  187         }
  188
  189         _ps.Text = "Clipboard";
  190         _ps.DockEnabled =
  191           DockSides.Left | DockSides.Right | DockSides.None;
  192         _ps.Size = new System.Drawing.Size(300, 500);
  193         _ps.Add("ClipboardView", _cv);
  194       }
  195       _ps.Visible = true;
  196     }
  197
  198
  199     // Our custom command to insert a raster image
  200
  201     [CommandMethod("RINS")]
  202     public void RasterInsert()
  203     {
  204       Document doc =
  205       Autodesk.AutoCAD.ApplicationServices.Application.
  206       DocumentManager.MdiActiveDocument;
  207       Database db = doc.Database;
  208       Editor ed = doc.Editor;
  209
  210       // Pick up the location of the bitmap image
  211
  212       PromptStringOptions pso =
  213         new PromptStringOptions(
  214           "\nPath of raster image: "
  215         );
  216       pso.AllowSpaces = true;
  217       PromptResult pr = ed.GetString(pso);
  218       if (pr.Status != PromptStatus.OK)
  219         return;
  220
  221       if (!File.Exists(pr.StringResult))
  222       {
  223         ed.WriteMessage(
  224           "\nFile does not exist."
  225         );
  226         return;
  227       }
  228
  229       string path = pr.StringResult;
  230
  231       // Pick up the position of the drop in screen coords
  232
  233       PromptPointOptions ppo =
  234         new PromptPointOptions(
  235           "\nPosition of raster image: "
  236         );
  237       PromptPointResult ppr = ed.GetPoint(ppo);
  238       if (pr.Status != PromptStatus.OK)
  239         return;
  240
  241       Point3d pos = ppr.Value;
  242
  243       // Calculate the displacement vector
  244
  245       Point3d pt =
  246         ed.PointToWorld(new Point((int)pos.X, (int)pos.Y));
  247       Matrix3d disp =
  248         Matrix3d.Displacement(pt - Point3d.Origin);
  249
  250       Transaction tr =
  251         db.TransactionManager.StartTransaction();
  252       using (tr)
  253       {
  254         // Get or create our raster image dictionary
  255
  256         ObjectId dictId =
  257           RasterImageDef.GetImageDictionary(db);
  258         if (dictId == ObjectId.Null)
  259           dictId = RasterImageDef.CreateImageDictionary(db);
  260
  261         // And open it for write
  262
  263         DBDictionary dict =
  264           (DBDictionary)tr.GetObject(
  265             dictId, OpenMode.ForWrite
  266           );
  267
  268         // Get a unique name for our definition object
  269
  270         string name = RasterImageDef.SuggestName(dict, path);
  271
  272         // Create the definition and add it to the dictionary
  273
  274         RasterImageDef rid = new RasterImageDef();
  275         rid.SourceFileName = path;
  276         rid.Load();
  277         ObjectId ridId = dict.SetAt(name, rid);
  278         tr.AddNewlyCreatedDBObject(rid, true);
  279
  280         // Now we'll add our raster image reference
  281         // to the current space
  282
  283         BlockTableRecord btr =
  284           (BlockTableRecord)tr.GetObject(
  285             db.CurrentSpaceId,
  286             OpenMode.ForWrite
  287           );
  288
  289         // Create and add the image reference
  290
  291         RasterImage ri = new RasterImage();
  292         ri.ImageDefId = ridId;
  293         ri.SetClipBoundaryToWholeImage();
  294         btr.AppendEntity(ri);
  295         tr.AddNewlyCreatedDBObject(ri, true);
  296         ri.TransformBy(disp);
  297
  298         // Of course we commit
  299
  300         tr.Commit();
  301       }
  302     }
  303   }
  304 }
The changes, as you can see, are very modest: the SendStringToExecute() call now sends the point in screen coordinates (adding a zero for Z, just to simplify collection by the command). The command collects and transforms the point before creating a displacement vector to apply to the raster image reference. The matrix gets applied to the image after it has been added to the drawing, but we could very well do so beforehand.
The code now allows the user to drop images from our palette at specific locations in the drawing:
I’m heading off to Las Vegas in the morning, but will hopefully still have time to post the jig update at the beginning of next week.
GMT+8, 2025-11-25 11:36 , Processed in 0.195118 second(s), 32 queries , Gzip On.
