楼主: lingduwx
寻求相同文字内容关联程序!!!
 楼主| 发表于 2012-7-27 13:20:40 | 显示全部楼层
Gu_xl 发表于 2012-7-27 09:35
[/post]
G版出手就是不一样啊,
不过小弟现在发现一个小问题,就是再次用此命令选择已关联字体时,CAD出现错误后关闭,
另外一个问题就是再次复制关联的文字时,偶想要默认是关联的,但是也可以输入N不关联,望G版解决一下,谢谢
发表于 2012-7-27 13:39:46 | 显示全部楼层
;;;;我也写了一个,添加关联用addgl,删除关联用delgl,显示关联用xsgl,复制文本不能产生关联。
我用的是命令反应器,只有一个反应器,不会使CAD崩溃。
ddedit命令结束时触发反应器。
(vl-load-com)
(if (not txt_gl)
    (setq txt_gl (VLR-Command-Reactor
                      nil
                      '((:VLR-commandEnded . GL-CALL))
(defun c:addgl ( / GLEDS GLS HANDS NEW_GL SS X txt)
  (if (setq ss (ssget '((0 . "*TEXT"))))
      (setq ss (OSS->VL-LIST ss))
      (setq hands (mapcar 'vla-get-handle ss))
      (setq gls (FENXI-GL hands))
      (if gls
          (setq gleds (vlax-ldata-list "CS_GUANLIAN"))
          (mapcar '(lambda (x)
                     (vlax-ldata-delete "CS_GUANLIAN" x)
                  gls
;;;删除旧的关联
          (setq        new_gl (mapcar '(lambda        (x / tmp)
                                  (cdr (assoc x gleds))
                               gls
          (setq        new_gl (mapcar '(lambda        (x)
                                  (mapcar 'car x)
                               new_gl
          (setq new_gl (apply 'append new_gl))
          (setq new_gl (append new_gl hands))
          (setq new_gl (remove-same new_gl))
        (setq new_gl hands)
      (setq txt (get-txt (car new_gl)))
      (mapcar '(lambda(x) (put-txt x txt)) new_gl)
      (put-gl new_gl)
      (princ "\n关联已经建立。")
(defun c:delgl (/ GLEDS GLS HANDS NEW_GL SS X)
      (if gls
                  gls
;;;删除旧的关联
                               gls
                                  (mapcar 'car x)
                               new_gl
          (foreach item        hands
            (setq new_gl (vl-remove item new_gl))
          (if (> (length new_gl) 1)
            (put-gl new_gl)
          (princ "\n关联已经解除。")
(defun c:xsgl ( / ENT ENTS GLEDS HAND HANDS X)
  (if (setq ent (car (entsel)))
      (setq ent (vlax-ename->vla-object ent))
      (setq hand (vla-get-handle ent))
      (setq gleds (mapcar '(lambda        (x)
                                  (mapcar 'car (cdr x))
                               gleds
      (setq gleds (vl-remove nil (mapcar '(lambda(x) (if (member hand x) x)) gleds)))
      (if gleds
          (setq hands (car gleds))
          (setq ents (vl-remove nil (mapcar 'handent hands)))
          (setq ents (mapcar 'vlax-ename->vla-object ents))
          (mapcar '(lambda(x) (vla-Highlight x :vlax-true)) ents)
(defun gl-call (aaa bbb / BJ_JG GLEDS GLS HANDS KEY OLD_GL TMP X Y)
  (if (= "DDEDIT" (strcase (car bbb)))
      (setq hands (mapcar '(lambda (x)
                             (cons (car x) (mapcar 'car (cdr x)))
                          gleds
      (setq
        gls (mapcar
              '(lambda (x)
                 (cons (car x)
                       (vl-remove nil
                                  (mapcar
                                    '(lambda (y)
                                       (if (setq tmp (get-txt y))
                                         (cons y tmp)
                                    (cdr x)
              hands
      (foreach item gls
        (setq key  (car item)
              item (cdr item)
        (setq old_gl (cdr (assoc key gleds)))
        (setq tmp
               (vl-remove
                 nil
                            (if        (/= (cdr x) (cdr (assoc (car x) old_gl)))
                              (cdr x)
                         item
        (if tmp
            (vlax-ldata-delete "CS_GUANLIAN" key)
            (setq bj_jg (last tmp))
            (setq item (mapcar '(lambda        (x)
                                  (put-txt (car x) bj_jg)
                                  (car x)
                               item
            (put-gl item)
(defun oss->vl-list (ss / I OUT TMP)
  (setq        i   -1
        out '()
  (repeat (sslength ss)
    (setq tmp (ssname ss (setq i (1+ i))))
    (setq tmp (vlax-ename->vla-object tmp))
    (setq out (cons tmp out))
  (reverse out)
(defun put-gl (lst / GL_DATA KEY TMP X)
  (if (> (length lst) 1)
      (setq key (car lst))
      (setq gl_data (vl-remove nil
                                          (if (setq tmp (GET-TXT x))
                                            (cons x tmp)
                                       lst
      (vlax-ldata-put "CS_GUANLIAN" key gl_data)
(defun fenxi-gl (lst / GLEDS OUT X Y)
  (setq gleds (mapcar '(lambda(x)
                      gleds))
  (setq out (vl-remove nil
              (mapcar '(lambda(x)
                       (vl-remove nil
                         (mapcar '(lambda(y)
                                  (if (member x y) (car y))
                               gleds)
                    lst)
  (remove-same (apply 'append out))
(defun remove-same (lst / OUT TMP)
  (setq out '())
  (while lst
    (setq tmp (car lst))
    (setq lst (vl-remove tmp lst))
  (reverse out)
(defun get-txt (hand / TMP)
  (if (and (setq tmp (handent hand))
           (not (vlax-erased-p tmp))
    (vla-get-textstring tmp)
(defun put-txt (hand txt / TMP)
    (vla-put-textstring tmp txt)
兄弟,顶你,因为只有一个最佳答案,所以不好意思,30 币送上,略表心意  发表于 2012-7-29 18:08
参与人数 3明经币 +5 金钱 +85 收起 理由
yoyoho + 1 + 50 赞一个!
lingduwx + 1 + 5 哎,怎么评分显示 明经币评分区0~1 ,今日剩.
Gu_xl + 3 + 30 赞一个!
发表于 2012-7-27 14:37:39 | 显示全部楼层
lingduwx 发表于 2012-7-27 13:20
G版出手就是不一样啊,
不过小弟现在发现一个小问题,就是再次用此命令选择已关联字体时,CAD出现错误后 ...
35楼代码已更新!
修正了已关联的物体再次关联时出错的问题!
增加取消关联命令: QXWZGL!关联后的文字被复制后,只要将原关联文字原位移动一下,或编辑一下,就自动关联!若不想关联,用取消关联命令选中复制的文字取消即可!
发表于 2012-7-27 14:46:36 | 显示全部楼层
顺路问下,有没有可以关联数字的哪?就像EXCEL中运算那样
论坛找一下,前几天我发过源码的!  发表于 2012-7-27 14:56
发表于 2012-7-27 16:27:00 | 显示全部楼层
试用了lijiao 和Gu_xl各有优势:
Gu_xl可在属性里修改文字,lijiao 只能双击修改
lijiao 可以关联后再关联即多重关联,Gu_xl只可一重
希望二们多改动,弄点经典的东东
别我坚持我的观点,相关联的成组,复制后不关联,命令越少越好
发表于 2012-7-27 17:45:11 | 显示全部楼层
lijiao 可以关联后再关联 ...
Gu_xl的可以正常运行,lrjiao的不能,06机械版,只能实现文字内容一样,改动一个其它的不变
发表于 2012-7-27 17:51:10 | 显示全部楼层
[/post]
G版你好!程序试用发现后只能一组一组的关联,我希望能实现“入党”功能,也就是A,B, C,是一组了,这时D也想加入,如何实现?目前我只使用一组,但组内成员的数量不定,希望能进群,也能退群
发表于 2012-7-27 17:55:20 | 显示全部楼层
我用的是 ...
你好!试用后发现不能实现关联,只能实现一次文字内容相同,也就是“文字内容刷”,可以实现“进群”,G版的不能加入新成员,有时间再修改一下,造福全人类
发表于 2012-7-27 18:56:13 来自手机 | 显示全部楼层
革天明 发表于 2012-7-27 17:55
你好!试用后发现不能实现关联,只能实现一次文字内容相同,也就是“文字内容刷”,可以实现“进群”,G版 ...
这个很容易,你把程序看懂了,实现这个用不了三五句代码,这个作为你的思考题,慢慢琢麽吧!
 楼主| 发表于 2012-7-27 20:53:32 | 显示全部楼层
Gu_xl 发表于 2012-7-27 14:37
35楼代码已更新!
增加取消关联命令: QXWZGL!关联后的文字 ...
非常感谢G版,程序非常不错,
现在就是想怎么把悬赏的150给你啊
悬赏的那儿我一直点不了
GMT+8, 2026-1-27 12:49 , Processed in 0.182568 second(s), 23 queries , Gzip On.
